I couldn’t resolve myself this issue.
I’ve created a terraform script to provide a vm with a additional volatile disk that I want to mount after creation. The datastore in a ceph rdb datastore (no issue in this side).
I’ve created templates with or without a second volatile disk. (first is a Ubuntu 22.04 image)
First: Terraform script doesn’t create the second disk although the template disk is specified. I had to specified the second disk in terraform script. No interest to use a template for this option.
Second: I tried different options to create my volatile disk :
- volatile_format = “raw” or “qcow2” → always create a raw disk
- volatile_type = “fs”
- driver = “raw” or not specified
- size = 100000 (the final size is 97.5 at this end, I didn’t understand why)
Problem: The vm is created, the disk is attach. Everything seems OK but:
The additional disk send this error on mounting : wrong fs type, bad option, bad superblock on /dev/sda, missing codepage or helper program, or other error.
It’s a ceph block behind, formatted in ext4. I checked the device with classic linux disk tools (e2fsck, fsck, etc…) always the same problem. Superblock issue.
With the same vm, if I detached the previous disk and I added a new disk with sunstone UI, miracle,
the new disk has been recognized, no error and mounting had not problem (with the right size 100Go).
The lonely difference is in terraform I can’t indicate the filesystem (etx4 in my case), no option of that.
Have you see this behavior before ?
Best regards
Olivier
