There is a way to resize CPU and RAM of a VM generated by a fixed template?
Hello everybody,
We have some templates with fixed CPU and RAM amounts
There is a way to force resize those parameters once the VM has been generated?
If I power off the VM and click “Resize”, CPU and RAM are greyed out
Thank you
Marco
You should be able to do so. Try using the CLI instead ? Maybe there is something Sunstone-related.
Yes, thank you!
Usign the CLI i was able to change the CPU and RAM assignement.
Strange that in sunstone i can’t change it, and I’m logged as oneadmin.
Maybe some dev can take a look into this?
Thank you!!
