where i need to keep following file
HOT_RESIZE = [
CPU_HOT_ADD_ENABLED = “YES”,
MEMORY_HOT_ADD_ENABLED = “YES”]
Hello @sudhakar,
You need to place those values in the VM template in the USER_TEMPLATE, e.g:
USER TEMPLATE
DEV_PREFIX="vd"
HOT_RESIZE=[
CPU_HOT_ADD_ENABLED="NO",
MEMORY_HOT_ADD_ENABLED="NO" ]
HYPERVISOR="vcenter"
INPUTS_ORDER=""
MEMORY_UNIT_COST="MB"
TYPE="OS"
VCENTER_CCR_REF="domain-c2001"
VCENTER_INSTANCE_ID="9f82ad22-7beb-404e-9595-bf73e9c672bc"
VCENTER_TEMPLATE_NAME="corelinux7_x86_64"
VCENTER_TEMPLATE_REF="vm-3018"
VCENTER_VM_FOLDER=""
Best,
Álex.
Thanks working for me
