Update Template Button does not work as expected in 4.14Beta2
Hello Guys,
After importing clusters and template using vCenter driver when I try to update the imported template it opens up a new template and there are no values of the existing template.
Not even the template UUID is shown inside it and I have to update all the attributes inside the template.
Seems to be a bug.
Regards
Kiran Ranjane
That is indeed a bug, solved now for the final release:
http://dev.opennebula.org/projects/opennebula/repository/revisions/d54c7081ec88df785448d9e43eface124ac4b526
Thanks a lot for your feedback!
