i have vcenter templates
can i mass edit a bunch of them and change something of the same in them all?
or maybe, alternatively are there templates file that i can edit on the linux level?
Hello @Liorme,
OpenNebula VMs templates are stored in the DB so you cannot update any file at linux level.
You can create a bash script with the help of onedb tool or you can use any of the existing bindings to do the changes at API level.
oh i see, thank you. but scripting is above me
