if I understand it correctly, the CPU parameter of a VM is only used for determining how many VMs is ONe allowed to cram into a single physical host. And the VCPU parameter means the number of threads qemu starts, which means the number of CPUs the virtual machine can see.
Now why it is not possible to change the CPU parameter of a running VM on the fly in the Sunstone VM -> Capacity tab? I have several VMs which have the CPU parameter set to be equal to VCPU, but the VM in question does not even remotely consume that much CPU. My end-users apparently do not understand the difference between CPU and VCPU, so I need to fix their already running misconfigured VMs.
How do you set up the CPU quotas and how do your users set the CPU parameters on non-computational clusters? Is CPU overcommitment the right solution to this problem?
Thanks!
