CPU > VCPU in VM Template
Does anyone know of a situation where it is reasonable to have the value of CPU greater than VCPU? In my understanding this is just blocking (say wasting) physical CPU resources.
Greetings
Wilma
In general it is better to think about VCPU and CPU as separate metrics.
CPU is to hypervisor allocation and over commitment, so for example CPU >
VCPU may let you to not place other VMs with a given one. For example you
if you have hosts with 8 cores, you could define a VM with VCPU=2 and
CPU=8; it may not use all the resources in the hypervisor but you also
prevent contention.
··· On Tue, Mar 8, 2016 at 10:38 AM, wilma_hermann wrote:
wilma_hermann https://forum.opennebula.io/users/wilma_hermann
March 8
Greetings
Wilma
Visit Topic
https://forum.opennebula.io/t/cpu-vcpu-in-vm-template/1909/1 or reply
to this email to respond
To stop receiving notifications for this particular topic, click here
https://forum.opennebula.io/t/cpu-vcpu-in-vm-template/1909/unsubscribe.
To unsubscribe from these emails, change your user preferences
https://forum.opennebula.io/my/preferences
Ruben S. Montero, PhD
Project co-Lead and Chief Architect
OpenNebula - Flexible Enterprise Cloud Made Simple
www.OpenNebula.org | rsmontero@opennebula.org | @OpenNebula
