Hi Carlos,
I have no previous experience dealing with Zombies VM, which I think are defined as VMs that were launched with OpenNebula but, for whatever reason, OpenNebula is not aware of this, e.g having different OpenNebula installations…
As another Carlos explains here:
…if the problematic VM was called one-* you may change its name in vCenter and try to reimport it but I think it’s not the case. As it’s not using the default one- prefix, was the Ubuntu1404 VM a wild VM imported to OpenNebula?
I’m just guessing… if it was an imported VM maybe there’s an entry in the database refering to that Ubuntu VM and that prevents it to be reimported and that’s why it’s shown in the Zombies Tab.
According to docs imported VMs have limitations (can’t be recovered, recreated, undeployed, migrated, stopped…) so perhaps that’s the way it should be and the backup method you proposed is not suitable for this kind of VMs… hope some user can provide its experience in backup and restoring.
Then in vCenter, as proposed in the vOneCloud forum…, try to “Remove the following entry from the VM advanced configuration: opennebula.vm.id”. Maybe that’s what is telling OpenNebula that the VM is a Zombie… I haven’t tested so I’m not sure if it’s safe to do this so proceed with caution!
