For few weeks, I have the same problem when I tried to add a second nic in a vm. Impossible to my vm to contact other vm in the second network (private network)
My context:
2 networks:
public network
private network with ovs and vxlan.
No problem with ovs to create a vm on each network.
I’ve created a virtual router on my private network, and vms work fine.
I try to create a vm for a HAPROXY (like the OneKE CE service).
But my vm works only on the public network.
Impossible to connect to the private network. I try with Alpine and Ubuntu. Exactly the same problem.
Only the first nic works well.
If I connect the nic on the private network. Only the private network works.
I can’t find in the context script how to manage the network.
I tried to use different routes tables but with no success.
My vms work for the moment (I don’t know why) but it seems that there’s a cooldown.
May be a cache in a router in my networks or different thing that I can’t manage in my level.
I had multi-issue. May be a resolved issue had solve this problem too.
ex: The server which provides one servers is in 2 networks (one dedicated to the vms and one connected in other machine). The onegate server address was in a wrong network in the oned.conf although the server listened in all interfaces (0.0.0.0). And the vms couldn’t access to onegate server directly.
I don’t understand exactly the role of the different servers to manage the context in vms. But I continue my tests.
