Hi everyone,
I have installed ONE 4.10.2 with the ESXi5.0 on CentOS 7, basically following this installation guide. Everything gone well, however the image datastore does not shows capacity, because of this I am unable to import images or create a VM.
Bridge_list is correct. The persistent passwordless SSH connection either.
ESXi Host IP: “10.235.2.225”
ONE Front-End IP: “10.235.2.227”
I suspect that there is some problem with the VMFS DS driver.
I have created a NFS shared datastore on the ONE front-end and mapped it trough the ESXi Host.
[oneadmin@localhost ~]$ ll /var/lib/one/datastores/
total 0
drwxr-x—. 2 oneadmin oneadmin 6 Jan 15 2015 0
drwxr-x—. 2 oneadmin oneadmin 6 Oct 15 01:16 1
drwxrwxr-x. 3 oneadmin oneadmin 16 Oct 15 01:39 103
drwxr-xr-x. 2 oneadmin oneadmin 6 Oct 14 21:55 2
NFS Share Details
/var/lib/one/datastores/0 *(rw,sync,no_subtree_check,root_squash,anonuid=9869,anongid=9869)
/var/lib/one/datastores/1 *(rw,sync,no_subtree_check,root_squash,anonuid=9869,anongid=9869)
Nfs share are mounted on Esxi Host with same Datastore Id
These Datastore are accessible by the Host, but the ONE front end can’t monitor the IMAGE_DS datastore. The
Datastore information:
[oneadmin@localhost ~]$ onedatastore list
ID NAME SIZE AVAIL CLUSTER IMAGES TYPE DS TM
0 system 8.5G 80% - 0 sys - vmfs
1 default 0M - - 0 img vmfs vmfs
2 files 8.5G 79% - 0 fil fs ssh
103 imagens 8.5G 79% - 1 img fs ssh
DATASTORE 1 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTER : -
TYPE : IMAGE
DS_MAD : vmfs
TM_MAD : vmfs
BASE PATH : /vmfs/volumes/1
DISK_TYPE : FILE
DATASTORE CAPACITY
TOTAL: : 0M
FREE: : 0M
USED: : 0M
LIMIT: : -
OWNER : um-
GROUP : u–
OTHER : u–
DATASTORE TEMPLATE
BASE_PATH=“/vmfs/volumes/”
BRIDGE_LIST=“10.235.2.225”
CLONE_TARGET=“SYSTEM”
DISK_TYPE=“FILE”
DS_MAD=“vmfs”
LN_TARGET=“NONE”
TM_MAD=“vmfs”
TYPE=“IMAGE_DS”
DATASTORE 0 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTER : -
TYPE : SYSTEM
DS_MAD : -
TM_MAD : vmfs
BASE PATH : /vmfs/volumes/0
DISK_TYPE : FILE
DATASTORE CAPACITY
TOTAL: : 8.5G
FREE: : 6.8G
USED: : 1.7G
LIMIT: : -
OWNER : um-
GROUP : u–
OTHER : —
DATASTORE TEMPLATE
SHARED=“YES”
TM_MAD=“vmfs”
TYPE=“SYSTEM_DS”
DATASTORE 103 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTER : -
TYPE : IMAGE
DS_MAD : fs
TM_MAD : ssh
BASE PATH : /var/lib/one/datastores/103/
DISK_TYPE : FILE
DATASTORE CAPACITY
TOTAL: : 8.5G
FREE: : 6.7G
USED: : 103M
LIMIT: : -
OWNER : um-
GROUP : u–
OTHER : u–
DATASTORE TEMPLATE
BASE_PATH=“/var/lib/one/datastores”
BRIDGE_LIST=“10.235.2.227”
DISK_TYPE=“FILE”
DS_MAD=“fs”
LN_TARGET=“SYSTEM”
TM_MAD=“ssh”
TYPE=“IMAGE_DS”
When I change the DS_TYPE to SYSTEM_DS, in the datastore 1, the ONE front-end monitor it normally.
Can anybody help me?
Thank you.
ONED.LOG
Tue Oct 18 23:20:01 2016 [Z0][ONE][I]: Starting OpenNebula 4.10.2
OpenNebula Configuration File
AUTH_MAD=AUTHN=ssh,x509,ldap,server_cipher,server_x509,EXECUTABLE=one_auth_mad
DATASTORE_BASE_PATH=/vmfs/volumes
DATASTORE_CAPACITY_CHECK=yes
DATASTORE_LOCATION=/vmfs/volumes
DATASTORE_MAD=ARGUMENTS=-t 15 -d dummy,fs,vmfs,lvm,ceph,dev,EXECUTABLE=one_datastore
DB=BACKEND=sqlite
DEFAULT_CDROM_DEVICE_PREFIX=sd
DEFAULT_DEVICE_PREFIX=sd
DEFAULT_IMAGE_TYPE=OS
DEFAULT_UMASK=177
ENABLE_OTHER_PERMISSIONS=YES
FEDERATION=MASTER_ONED=,MODE=STANDALONE,ZONE_ID=0
HM_MAD=EXECUTABLE=one_hm
HOST_MONITORING_EXPIRATION_TIME=43200
HOST_PER_INTERVAL=15
IMAGE_RESTRICTED_ATTR=SOURCE
IM_MAD=ARGUMENTS=-p 4124 -f 5 -t 50 -i 20,EXECUTABLE=collectd,NAME=collectd
IM_MAD=ARGUMENTS=-r 3 -t 15 kvm,EXECUTABLE=one_im_ssh,NAME=kvm
IM_MAD=ARGUMENTS=-r 3 -t 15 xen4,EXECUTABLE=one_im_ssh,NAME=xen
IM_MAD=ARGUMENTS=-c -t 15 -r 0 vmware,EXECUTABLE=one_im_sh,NAME=vmware
INHERIT_DATASTORE_ATTR=CEPH_HOST
INHERIT_DATASTORE_ATTR=CEPH_SECRET
INHERIT_DATASTORE_ATTR=CEPH_USER
INHERIT_DATASTORE_ATTR=GLUSTER_HOST
INHERIT_DATASTORE_ATTR=GLUSTER_VOLUME
INHERIT_VNET_ATTR=VLAN_TAGGED_ID
INHERIT_VNET_ATTR=BRIDGE_OVS
KEEPALIVE_MAX_CONN=30
KEEPALIVE_TIMEOUT=15
LOG=DEBUG_LEVEL=3,SYSTEM=file
LOG_CALL_FORMAT=Req:%i UID:%u %m invoked %l
MAC_PREFIX=02:00
MANAGER_TIMER=15
MAX_CONN=15
MAX_CONN_BACKLOG=15
MESSAGE_SIZE=1073741824
MONITORING_INTERVAL=60
MONITORING_THREADS=50
NETWORK_SIZE=254
PORT=2633
RPC_LOG=NO
SCRIPTS_REMOTE_DIR=/var/tmp/one
SESSION_EXPIRATION_TIME=900
TIMEOUT=15
TM_MAD=ARGUMENTS=-t 15 -d dummy,lvm,shared,fs_lvm,qcow2,ssh,vmfs,ceph,dev,EXECUTABLE=one_tm
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=NONE,NAME=dummy,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=SELF,LN_TARGET=NONE,NAME=lvm,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=NONE,NAME=shared,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=SYSTEM,NAME=fs_lvm,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=NONE,NAME=qcow2,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=SYSTEM,NAME=ssh,SHARED=no
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=NONE,NAME=vmfs,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=SELF,LN_TARGET=NONE,NAME=ceph,SHARED=yes
TM_MAD_CONF=CLONE_TARGET=NONE,LN_TARGET=NONE,NAME=dev,SHARED=yes
VM_INDIVIDUAL_MONITORING=no
VM_MAD=ARGUMENTS=-t 15 -r 0 kvm,DEFAULT=vmm_exec/vmm_exec_kvm.conf,EXECUTABLE=one_vmm_exec,NAME=kvm,TYPE=kvm
VM_MAD=ARGUMENTS=-t 15 -r 0 xen4,DEFAULT=vmm_exec/vmm_exec_xen4.conf,EXECUTABLE=one_vmm_exec,NAME=xen,TYPE=xen
VM_MAD=ARGUMENTS=-t 15 -r 0 vmware -s sh,DEFAULT=vmm_exec/vmm_exec_vmware.conf,EXECUTABLE=one_vmm_sh,NAME=vmware,TYPE=vmware
VM_MONITORING_EXPIRATION_TIME=14400
VM_PER_INTERVAL=5
VM_RESTRICTED_ATTR=CONTEXT/FILES
VM_RESTRICTED_ATTR=NIC/MAC
VM_RESTRICTED_ATTR=NIC/VLAN_ID
VM_RESTRICTED_ATTR=NIC/BRIDGE
VM_RESTRICTED_ATTR=NIC_DEFAULT/MAC
VM_RESTRICTED_ATTR=NIC_DEFAULT/VLAN_ID
VM_RESTRICTED_ATTR=NIC_DEFAULT/BRIDGE
VM_RESTRICTED_ATTR=DISK/TOTAL_BYTES_SEC
VM_RESTRICTED_ATTR=DISK/READ_BYTES_SEC
VM_RESTRICTED_ATTR=DISK/WRITE_BYTES_SEC
VM_RESTRICTED_ATTR=DISK/TOTAL_IOPS_SEC
VM_RESTRICTED_ATTR=DISK/READ_IOPS_SEC
VM_RESTRICTED_ATTR=DISK/WRITE_IOPS_SEC
VM_SUBMIT_ON_HOLD=NO
VNC_BASE_PORT=5900
VNET_RESTRICTED_ATTR=PHYDEV
VNET_RESTRICTED_ATTR=VLAN_ID
VNET_RESTRICTED_ATTR=BRIDGE
VNET_RESTRICTED_ATTR=AR/PHYDEV
VNET_RESTRICTED_ATTR=AR/VLAN_ID
VNET_RESTRICTED_ATTR=AR/BRIDGETue Oct 18 23:20:01 2016 [Z0][ONE][I]: Log level:3 [0=ERROR,1=WARNING,2=INFO,3=DEBUG]
Tue Oct 18 23:20:01 2016 [Z0][ONE][I]: Support for xmlrpc-c > 1.31: yes
Tue Oct 18 23:20:01 2016 [Z0][ONE][I]: Checking database version.
Tue Oct 18 23:20:01 2016 [Z0][ONE][I]: oned is using version 4.9.80 for local_db_versioning
Tue Oct 18 23:20:01 2016 [Z0][ONE][I]: oned is using version 4.6.0 for db_versioning
Tue Oct 18 23:20:01 2016 [Z0][ACL][I]: Starting ACL Manager…
Tue Oct 18 23:20:01 2016 [Z0][ACL][I]: ACL Manager started.
Tue Oct 18 23:20:01 2016 [Z0][VMM][I]: Starting Virtual Machine Manager…
Tue Oct 18 23:20:01 2016 [Z0][LCM][I]: Starting Life-cycle Manager…
Tue Oct 18 23:20:01 2016 [Z0][InM][I]: Starting Information Manager…
Tue Oct 18 23:20:01 2016 [Z0][TrM][I]: Starting Transfer Manager…
Tue Oct 18 23:20:01 2016 [Z0][DiM][I]: Starting Dispatch Manager…
Tue Oct 18 23:20:01 2016 [Z0][HKM][I]: Starting Hook Manager…
Tue Oct 18 23:20:01 2016 [Z0][AuM][I]: Starting Auth Manager…
Tue Oct 18 23:20:01 2016 [Z0][ImM][I]: Starting Image Manager…
Tue Oct 18 23:20:02 2016 [Z0][AuM][I]: Authorization Manager started.
Tue Oct 18 23:20:02 2016 [Z0][ImM][I]: Image Manager started.
Tue Oct 18 23:20:02 2016 [Z0][InM][I]: Information Manager started.
Tue Oct 18 23:20:02 2016 [Z0][VMM][I]: Virtual Machine Manager started.
Tue Oct 18 23:20:02 2016 [Z0][TrM][I]: Transfer Manager started.
Tue Oct 18 23:20:02 2016 [Z0][DiM][I]: Dispatch Manager started.
Tue Oct 18 23:20:02 2016 [Z0][LCM][I]: Life-cycle Manager started.
Tue Oct 18 23:20:02 2016 [Z0][HKM][I]: Hook Manager started.
Tue Oct 18 23:20:02 2016 [Z0][VMM][I]: Loading Virtual Machine Manager drivers.
Tue Oct 18 23:20:02 2016 [Z0][VMM][I]: Loading driver: kvm (KVM)
Tue Oct 18 23:20:03 2016 [Z0][VMM][I]: Driver kvm loaded.
Tue Oct 18 23:20:03 2016 [Z0][VMM][I]: Loading driver: xen (XEN)
Tue Oct 18 23:20:03 2016 [Z0][VMM][I]: Driver xen loaded.
Tue Oct 18 23:20:03 2016 [Z0][VMM][I]: Loading driver: vmware (VMWARE)
Tue Oct 18 23:20:03 2016 [Z0][VMM][I]: Driver vmware loaded.
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Loading Information Manager drivers.
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Loading driver: collectd
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Driver collectd loaded
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Loading driver: kvm
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Driver kvm loaded
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Loading driver: xen
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Driver xen loaded
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Loading driver: vmware
Tue Oct 18 23:20:03 2016 [Z0][InM][I]: Driver vmware loaded
Tue Oct 18 23:20:03 2016 [Z0][TM][I]: Loading Transfer Manager driver.
Tue Oct 18 23:20:03 2016 [Z0][TM][I]: Transfer manager driver loaded
Tue Oct 18 23:20:03 2016 [Z0][HKM][I]: Loading Hook Manager driver.
Tue Oct 18 23:20:04 2016 [Z0][HKM][I]: Hook Manager loaded
Tue Oct 18 23:20:04 2016 [Z0][ImM][I]: Loading Image Manager driver.
Tue Oct 18 23:20:04 2016 [Z0][ImM][I]: Image Manager loaded
Tue Oct 18 23:20:04 2016 [Z0][AuM][I]: Loading Auth. Manager driver.
Tue Oct 18 23:20:04 2016 [Z0][AuM][I]: Auth Manager loaded
Tue Oct 18 23:20:04 2016 [Z0][ReM][I]: Starting Request Manager…
Tue Oct 18 23:20:04 2016 [Z0][ReM][I]: Starting XML-RPC server, port 2633 …
Tue Oct 18 23:20:04 2016 [Z0][ReM][I]: Request Manager started.
Tue Oct 18 23:20:06 2016 [Z0][ReM][D]: Req:4032 UID:0 SystemConfig invoked
Tue Oct 18 23:20:06 2016 [Z0][ReM][D]: Req:4032 UID:0 SystemConfig result SUCCESS, “<AUTH_MAD>…”
Tue Oct 18 23:20:16 2016 [Z0][InM][D]: Monitoring datastore default (1)
Tue Oct 18 23:20:17 2016 [Z0][InM][D]: Monitoring datastore files (2)
Tue Oct 18 23:20:17 2016 [Z0][InM][D]: Monitoring datastore imagens (103)
Tue Oct 18 23:20:17 2016 [Z0][ImM][D]: Datastore imagens (103) successfully monitored.
Tue Oct 18 23:20:17 2016 [Z0][ImM][D]: Datastore files (2) successfully monitored.
Tue Oct 18 23:20:17 2016 [Z0][ImM][D]: Datastore default (1) successfully monitored.
Tue Oct 18 23:20:32 2016 [Z0][InM][D]: Monitoring host 10.235.2.225 (0)
Tue Oct 18 23:20:34 2016 [Z0][ImM][D]: Datastore system (0) successfully monitored.
Tue Oct 18 23:20:34 2016 [Z0][InM][D]: Host 10.235.2.225 (0) successfully monitored.
Tue Oct 18 23:20:35 2016 [Z0][ReM][D]: Req:9136 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Tue Oct 18 23:20:35 2016 [Z0][ReM][D]: Req:9136 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL></VM_POOL>”
Tue Oct 18 23:20:36 2016 [Z0][ReM][D]: Req:1152 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Tue Oct 18 23:20:36 2016 [Z0][ReM][D]: Req:1152 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL></VM_POOL>”
Tue Oct 18 23:21:06 2016 [Z0][ReM][D]: Req:5040 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Tue Oct 18 23:21:06 2016 [Z0][ReM][D]: Req:5040 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL></VM_POOL>”
Tue Oct 18 23:21:06 2016 [Z0][ReM][D]: Req:3168 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Tue Oct 18 23:21:06 2016 [Z0][ReM][D]: Req:3168 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL></VM_POOL>”
Tue Oct 18 23:21:13 2016 [Z0][InM][D]: Monitoring datastore default (1)
Tue Oct 18 23:21:13 2016 [Z0][InM][D]: Monitoring datastore files (2)
Tue Oct 18 23:21:13 2016 [Z0][InM][D]: Monitoring datastore imagens (103)
Tue Oct 18 23:21:14 2016 [Z0][ImM][D]: Datastore files (2) successfully monitored.
Tue Oct 18 23:21:14 2016 [Z0][ImM][D]: Datastore imagens (103) successfully monitored.
Tue Oct 18 23:21:14 2016 [Z0][ImM][D]: Datastore default (1) successfully monitored.
Tue Oct 18 23:21:36 2016 [Z0][ReM][D]: Req:8960 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Tue Oct 18 23:21:36 2016 [Z0][ReM][D]: Req:8960 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL></VM_POOL>”
Tue Oct 18 23:21:36 2016 [Z0][ReM][D]: Req:1136 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Tue Oct 18 23:21:36 2016 [Z0][ReM][D]: Req:1136 UID:0 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL></VM_POOL>”
