VMRC with reverse proxy
Hello together
I would like to use opennebula with a reverse proxy.
Opennebula itself works as well, but the VMRC console can’t connect anymore. Is there a guide what to configure this ?
Could you tell us the exact problem you have? What reverse proxy are you using? How is it configured?
VMRC should work fine with the correct configuration. We recommend reading here to understand how OpenNebula is configured for large deployments.
