abdullah
(Abdullah )
October 30, 2019, 12:50pm
1
novnc log
hamo - - [30/Oct/2019 12:26:27] 192.168.122.1: Plain non-SSL (ws://) WebSocket connection
hamo - - [30/Oct/2019 12:26:27] 192.168.122.1: Version hybi-13, base64: 'False'
hamo - - [30/Oct/2019 12:26:27] 192.168.122.1: Path: '/?token=9wpxwe4kh5z9abr9mwwm'
hamo - - [30/Oct/2019 12:26:27] connecting to: hostnode2:5931
handler exception: [Errno -3] Temporary failure in name resolution
hamo - - [30/Oct/2019 12:29:32] 192.168.122.1: Plain non-SSL (ws://) WebSocket connection
hamo - - [30/Oct/2019 12:29:32] 192.168.122.1: Version hybi-13, base64: 'False'
hamo - - [30/Oct/2019 12:29:32] 192.168.122.1: Path: '/?host=192.168.122.198&port=29876&token=48uhgpvdgyifnm88ei18&encrypt=no&title=Ubuntu%2016.04%20-%20KVM-32&password=null'
I am using the latest release of opnnebula 5.9.9.0 from githib repo. I buillt it form source.
I have virtual setup.
I installed opnenbula on a virtual machine and connected to a virtual host.
the port 5932 is accesable form the host not from the frontend.
this the output of sudo lsof -i -P -n | grep LISTEN command
oned 1910 oneadmin 22u IPv4 33014 0t0 TCP *:2633 (LISTEN)
ruby 2456 oneadmin 10u IPv4 35173 0t0 TCP *:9869 (LISTEN)
ruby 2481 oneadmin 11u IPv4 35145 0t0 TCP 127.0.0.1:2474 (LISTEN)
python 8245 oneadmin 0u IPv4 112646 0t0 TCP *:29876 (LISTEN)
ruby 19233 oneadmin 13u IPv4 253557 0t0 TCP 127.0.0.1:2101 (LISTEN)
ruby 19233 oneadmin 15u IPv4 253559 0t0 TCP 127.0.0.1:2102 (LISTEN)
ahuertas
(Alejandro Huertas)
October 30, 2019, 3:58pm
2
Hello @abdullah
Did you set up secure ws on sunstone-server.conf or are you just using plain ws?
abdullah
(Abdullah )
October 31, 2019, 8:02am
3
Hello @ahuertas
Thank you for replying. I plain just plain ws.
ahuertas
(Alejandro Huertas)
October 31, 2019, 8:15am
4
And are you using KVM or vCenter?
abdullah
(Abdullah )
October 31, 2019, 10:50am
5
Thank you for your intrest. I am using kvm.
ahuertas
(Alejandro Huertas)
October 31, 2019, 1:43pm
6
You are welcome!
So, do you get any error in the browser console when trying to connect to the VNC? Just open it and send me a screenshot.
abdullah
(Abdullah )
November 3, 2019, 7:42am
7
Sorry to be late in the reply.
this screen shot when I click on the vnc icon is the
abdullah
(Abdullah )
8
and this when I open in I click on “open in a new window”
ahuertas
(Alejandro Huertas)
November 4, 2019, 10:02am
9
But, in the console browser, do you get any error?
saint
(saint_)
January 31, 2020, 4:07pm
12
I had exactly the same issue, and it was because of SSL certificates and NoVNC services.
Look at novnc error log, and nginx eventually.
bouzeghoub
(IT solutions)
February 5, 2021, 9:33am
13
Please I have a same problem with vCenter.
Best regards.
Good topic.
I’m facing same issue:
websock.js:212 WebSocket connection to ‘wss://www.example.fr:29876/?host=www.example.fr &port=29876&token=ps4ul4wuvmalgesjgi69&encrypt=yes&title=test01&password=null’ failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT
Regards
sbetanzos
(Sergio Betanzos)
February 8, 2021, 10:35am
15
Please check that the following ports are open:
- Browser <-> Sunstone Server TCP 29876
- Sunstone Server <-> Hypervisor TCP 5900 + VM_ID
ballzop
(ballzop)
June 29, 2021, 7:54am
16
VNC consoles are returning “Something went wrong, connection is closed” while doing a minor update. .
My environment:
It’s seems that I facing the same issue when try to access VNC.
Log from /var/log/one/novnc.log:
localhost.localdomain - - [02/Feb/2022 12:38:44] 127.0.0.1: SSL/TLS (wss://) WebSocket connection
localhost.localdomain - - [02/Feb/2022 12:38:44] 127.0.0.1: Version hybi-13, base64: 'False'
localhost.localdomain - - [02/Feb/2022 12:38:44] 127.0.0.1: Path: '/websockify?port=443/websockify&encrypt=yes&token=7gwbewppz2ud8nluka7e&info=eyJpZCI6IjIxNDUiLCJuYW1lIjoiU1RfVWJ1bnR1X1RydWVOQVMtOCIsInN0YXRlIjoiUlVOTklORyIsInN0YXJ0X3RpbWUiOiIxNjQyNTA4NDExIiwibmV0d29ya3MiOlsiMTkyLjE2OC4zLjY0Il19'
localhost.localdomain - - [02/Feb/2022 12:38:44] connecting to: c2.##redacted##:8045
Port is already open at the host node. Also between frontend and node can communicate using private IP.
root@c2.##redacted## ~
[ #redacted# ] # netstat -lnptu|grep 8045
tcp 0 0 192.168.3.12:8045 0.0.0.0:* LISTEN 1006/qemu-kvm-one
Error log from browser console:
Any idea for this issue?
Regards,
Harry
Ah I see.
I have this vnc_request_password: true configured in /etc/one/sunstone-server.conf.
I set to vnc_request_password: false, VNC console now active.
Question: I know about the password I can see on VM details.
How can I input the password when the vnc_request_password: true ?
system
(system)
Closed
June 25, 2025, 3:48pm
19
