VNC icon dissaper
Hey guys.
I faced with issue, after I created a federation with two zones, I found that vnc consoles icons disappeared from the slave cluster, if I switch to slave from master with WEB UI they visible ok, but if I try to log in on slave cluster directly that is no vnc picture neither in the list of vm nor in the vm settings. but if vm’s settings load not too quick I see VNC picture and after a moment it disappears.
Hi @Leonid,
Your issue is related with: https://github.com/OpenNebula/one/issues/738
Hi Christian !
Thank you!
