We have a use-case where another service outside of Open Nebula will add KVM VMs to shared hosts also under control of Open Nebula.
I like the Wild VM concept and I see the Open Nebula monitored host noticed the VM as Wild. As best I can tell while Open Nebula host monitor finds the VM and its resource allocations, it does NOT use those values in reporting the KVM hosts total allocated memory and cpu?
Is that correct? I even check debug schedular logs on allocation of a new Open Nebula created VMs. The Scheduler data used to select host/resources statistics don’t include the Wild VM when evaluation host resources. (It appears)
Additional questions below with details.
clip from ‘onehost show 20’ (BEFORE IMPORT)
CLUSTER : onprem-cluster-laas-1a
STATE : MONITORED
IM_MAD : kvm
VM_MAD : kvm
LAST MONITORING TIME : 12/05 19:31:00
HOST SHARES
RUNNING VMS : 4
MEMORY
TOTAL : 503.5G
TOTAL +/- RESERVED : 503.5G
USED (REAL) : 7G
USED (ALLOCATED) : 12.8G
CPU
TOTAL : 9600
TOTAL +/- RESERVED : 9600
USED (REAL) : 0
USED (ALLOCATED) : 1550
LOCAL SYSTEM DATASTORE #133 CAPACITY
TOTAL: : 97.9G
USED: : 18.9G
FREE: : 74G
WILD VIRTUAL MACHINES
NAME IMPORT_ID CPU MEMORY
Deployer_1.29_2024.03.1.i bf3ec87a-1a6e-4cdc-a36d-e86a070fbeba 30 24576
VIRTUAL MACHINES
ID USER GROUP NAME STAT CPU MEM HOST TIME
257 oneadmin oneadmin kentest2 runn 0.5 768M s002-m5-40g-kvm27.mitg-bxb300.cisco 0d 00h50
254 oneadmin oneadmin ToolsHosts_2_(service_90) runn 5 4G s002-m5-40g-kvm27.mitg-bxb300.cisco 1d 06h45
252 oneadmin oneadmin ToolsHosts_0_(service_90) runn 5 4G s002-m5-40g-kvm27.mitg-bxb300.cisco 1d 06h45
250 oneadmin oneadmin ToolsHosts_1_(service_89) runn 5 4G s002-m5-40g-kvm27.mitg-bxb300.cisco 1d 06h54
scheduler log: ( force placement of a new VM to see if scheduler totals would take the WILD vm into account.)
CLUSTER_ID : 117
PUBLIC : 0
MEM_USAGE : 13369344 <<< is same 13,356MB as show on OpenNebula VM onehost above, so no accounting for the Wild VM.
CPU_USAGE : 1550
MAX_MEM : 527984052
MAX_CPU : 9600
FREE_DISK : 75729
RUNNING_VMS : 4
Is there a configurable to have the Wild resources accounted for in host totals reported by Open Nebula?
Once I “import” the wild VM then, yes its accounted for. Thats an extra step and a nice option. I could live with that but noticed this is the v6.10.0 documentation
This command is deprecated and will be removed in future release. Imported VMs will be removed from OpenNebula management and will appear again as wild VMs on the host.
Once its Depreciated, will the Wild Resources be accounted for?
Imported wild VM and now Totals are correct:
MEMORY
TOTAL : 503.5G
USED (REAL) : 9.7G
USED (ALLOCATED) : 38.8G
CPU
TOTAL : 9600
USED (REAL) : 0
USED (ALLOCATED) : 4600
VIRTUAL MACHINES
260 oneadmin oneadmin Deployer_1.29_2024.03.1.i12-K8Only runn 30 24G s002-m5-40g-kvm27.mitg-bxb300.cisco 0d 00h02
259 oneadmin oneadmin new VM runn 0.5 2G s002-m5-40g-kvm27.mitg-bxb300.cisco 0d 00h08
257 oneadmin oneadmin kentest2 runn 0.5 768M s002-m5-40g-kvm27.mitg-bxb300.cisco 0d 01h03
254 oneadmin oneadmin ToolsHosts_2_(service_90) runn 5 4G s002-m5-40g-kvm27.mitg-bxb300.cisco 1d 06h58
252 oneadmin oneadmin ToolsHosts_0_(service_90) runn 5 4G s002-m5-40g-kvm27.mitg-bxb300.cisco 1d 06h58
250 oneadmin oneadmin ToolsHosts_1_(service_89) runn 5 4G s002-m5-40g-kvm27.mitg-bxb300.cisco 1d 07h07
root@opennebular-1:/var/log/one#
