Yeah sure. But how detects opennebula which vnc port is used? Here is the a running wild VM which gets detected by opennebula but vnc is not working.
hn ~ # ps auxw | grep freepbx
qemu      2522  8.7 11.0 8737384 1803056 ?     Sl   11:09   4:27 /usr/bin/qemu-system-x86_64 -name freepbx -S -machine pc-q35-2.4,accel=kvm,usb=off -m 4096 -realtime mlock=off -smp 4,sockets=4,cores=1,threads=1 -uuid fc95a078-be71-4ee3-84b7-0e947d0304d5 -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-freepbx/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc -no-shutdown -boot strict=on -device i82801b11-bridge,id=pci.1,bus=pcie.0,addr=0x1e -device pci-bridge,chassis_nr=2,id=pci.2,bus=pci.1,addr=0x1 -device piix3-usb-uhci,id=usb,bus=pci.2,addr=0x3 -device virtio-serial-pci,id=virtio-serial0,bus=pci.2,addr=0x2 -drive file=/var/lib/libvirt/images/freepbx.qcow2,if=none,id=drive-virtio-disk0,format=qcow2,cache=writethrough,aio=threads -device virtio-blk-pci,scsi=off,bus=pci.2,addr=0x4,drive=drive-virtio-disk0,id=virtio-disk0,bootindex=1 -netdev tap,fd=25,id=hostnet0,vhost=on,vhostfd=26 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:26:1a:4b,bus=pci.2,addr=0x1 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev socket,id=charchannel0,path=/var/lib/libvirt/qemu/f16x86_64.agent,server,nowait -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 -vnc 127.0.0.1:3 -device cirrus-vga,id=video0,bus=pcie.0,addr=0x1 -device virtio-balloon-pci,id=balloon0,bus=pci.2,addr=0x5 -msg timestamp=on
cheers
t.
