Alerting and Monitoring Compatibility with OpenNebula 6.4 Version
Hi Team,
I have successfully completed the alerting and monitoring setup for OpenNebula version 6.10 by following the official documentation here:
All components including:
  • VM Monitoring
  • NEBULA_MONITOR
  • HOST MONITOR
are working as expected.
Could you please confirm if the same alerting and monitoring features are available in OpenNebula version 6.4?
If yes, kindly provide the corresponding installation or configuration documentation link for version 6.4.
Hello @Senthil_Kumar_M,
Can you let us know why you need to use the 6.4 if you successfully use it on 6.10?
For documentation on 6.4, you can go here: Monitoring. Where you can find the info of what’s supported in that version.
However, please note that version 6.4 is no longer supported, and you can find bugs or other issues that has been solved in 6.10.
Cheers,
