Hello Team,
We have upgraded from OpenNebula 4.12 to 4.14 and all is working fine less the Appmarket (2.1).
This command works
oneadmin@node1:~$ appmarket list
ID NAME PUBLISHER
54b3f242cf723241e8000001 Windows Server2008 R2 SRP
54b3f2d5cf723241e8000002 Centos 6x SRP
54b3f310cf723241e8000003 Ubuntu 12.04.x SRP
54b3f34bcf723241e8000004 Windows 2012 R2 SRP
In Sunstone we see this message " Showing 1 to 4 of 4 entries" however we cannot see the appliances. We reviewed again our settings and all looks ok.
Thanks for your support.
esfreire
(Esteban Freire)
February 5, 2016, 4:56pm
2
Hello Eddy,
Maybe, my post about it can help you
Hello all,
I just wanted to write some feedback about OpenNebula 4.14.2 release to share with you
First of all, I would like to say that we have upgraded successfully our test environment to the 4.14.2 release from the 4.12.1 and we also have run the first 3D modelling test by using Blender in an Ubuntu Desktop VM with GPUs configured on it since now it is possible to configure/pass GPU on the VM template.
We still need to test old and new OpenNebula features but I wanted to sh…
Also please check that you have the following line on the sunstone-server.conf:
# Marketplace endpoint
# The url should not include the /appliance path since it will be automatically
# included
:marketplace_url: http://marketplace.opennebula.systems/
I hope it helps
Regards,
Esteban
Hi Esteban,
Thank you very much for your answer. Unfortunately, my issue is not related with the marketplace, it is related with the Appmarket.
dmolina
(Daniel Molina)
February 10, 2016, 8:26am
4
Could you check if there is any error in the browser developer console?
Hi Daniel,
Attached is a print of the console. Thank you for your support.
dmolina
(Daniel Molina)
February 12, 2016, 9:02am
6
What steps did you follow to upgrade AppMarket and include the tabs in Sunstone?
Please check that the enabled tabs section in /etc/one/sunstone-views/admin.yaml is an array and not a hash
# Array
- appmarket-dashboard-tab
- appmarket-apps-tab
vs
# Hash
appmarket-dashboard-tab: true
appmarket-apps-tab: true
Hi Daniel,
We followed the instructions of the below link. Also we used Array for the settings in in /etc/one/sunstone-views/admin.yaml
We appreciate your support.
dmolina
(Daniel Molina)
February 17, 2016, 10:57am
8
Could you change the env parameter of the sunstone server to dev and restart the server
# Memcache configuration
:memcache_host: localhost
:memcache_port: 11211
:memcache_namespace: opennebula.sunstone
# Excution environment for Sunstone
# dev, Instead of pulling the minified js all the files will be pulled (app/main.js)
# Check the Building from Source guide in the docs, for details on how to run
# Sunstone in development
# prod, the minified js will be used (dist/main.js)
:env: 'prod'
# Maximum allowed size of uploaded images (in bytes). Leave commented for
# unlimited size
# :max_upload_file_size: 10737418240 # 10 GiB
# Log
# Log debug level
sunstone.rar (7.2 KB)
Hi Daniel,
I applied your instructions. Attached the sunstone.log. I did not see any error there.
I appreciate your support.
dmolina
(Daniel Molina)
February 17, 2016, 3:33pm
10
This parameter only changes the files that are used in the client side, so logs should be the same.
Do you see the same problem with the Appliances tab running Sunstone in dev mode?
Yes, I see the same issue. Sunstone knows there are 4 appliances but it does not list to them.
dmolina
(Daniel Molina)
February 17, 2016, 4:10pm
12
Could you discard cache issues, disabling the cache in your browser
Hi Daniel,
We have disabled the cache in my browser but the issue still.
