Hi all,
I have updated to the atest version of Open Nebula. Everything is looking well so far, but I keep having issues to configure and use the AppMarket. Maybe you can help me out
I am following this documentation:
first step, “Installation and cofiguration”,
was Ok, no errors.
however, there are several issues:
1.- my server (localhost::6242/appliance) has no appliances.
2.- If I go to Sunstone -> AppMarket-> Appliances, it is empty too. Shouldn’t I be seing the official OpenNebula ones?
3.- All buttons except “+” (import, update, convert) are disabled.
Is all this normal, or is there any missconfiguration?
I move then to thenext step, “Usage”
I can create users as specified in “Managing users”, but I am not able to list them or any other operation, either with root or oneadmin. Any thoughts on this? Have you got any suggested user organization?
So i guess i am starting to take wrong decissions here.
Last I move to the last section, “AppMarket-Worker”
Installation is OK.
User creation, as specified on that link, returns an error
"message": "KEY: 'role' is not allowed; SCHEMA: {:type=>:null, :default=>\"user\"}"
and
"message": "KEY: 'status' is not allowed; SCHEMA: {:type=>:null, :default=>\"disabled\"}"
and then basically I don’t know what to do so I stop here.
Then, if on Sunstone I try to create a new appliance to convert an OVA (in particular, this one)
I get a “User not authorized” error.
I assume that I am not performing some basic opperations, but I am pretty lost at this point and I would really appreciate some orientation on how to proceed.
Thanks for your help.
Best regards,
Manuel
