if i have a vm with a static mac, and i turn it off via opennebula. when i turn it on i get " [Impermissible static ethernet address"
from what i’ve seen, the opennebula do a “reconfig” of the vmx file, and removes the line " **ethernet0.checkMACAddress = “false” from it
if i insert the line manually and turn on the vm from the vcenter, it turnes on fine. but now, the opennebula is unaware of the vm status because he’s not the one to turn it on, so he keeps thinking that the vm is always off.
5.6.1
simply turn off a machine with a static mac, and try to turn it back on via opennebula
the vm wont turn on, you get an error stated above
