follwoing with below to setup On-Premises HCI Cluster but have role ‘stackhpc.systemd_networkd’ was not found
https://docs.opennebula.io/6.8/provision_clusters/hci_clusters/onprem_cluster_ceph.html
Expected behavior
PLAY RECAP *********************************************************************
10.161.250.146 : ok=48 changed=3 unreachable=0 failed=0 skipped=39 rescued=0 ignored=0
10.161.250.147 : ok=48 changed=3 unreachable=0 failed=0 skipped=39 rescued=0 ignored=0
10.161.250.148 : ok=48 changed=3 unreachable=0 failed=0 skipped=39 rescued=0 ignored=0
2024-06-24 04:14:06 DEBUG : Command succeeded
2024-06-24 04:14:06 DEBUG : Command run: ANSIBLE_CONFIG=/tmp/d20240624-29146-1tn87vu/ansible.cfg ansible-playbook --ssh-common-args=‘-o UserKnownHostsFile=/dev/null’ -i /tmp/d20240624-29146-1tn87vu/inventory -i /tmp/d20240624-29146-1tn87vu/ceph_inventory.yml -e @/tmp/d20240624-29146-1tn87vu/ceph_group_vars.yml /usr/share/one/oneprovisio n/ansible/ceph_hci/site.yml
ERROR! the role ‘stackhpc.systemd_networkd’ was not found in /usr/share/one/oneprovision/ansible/ceph_hci/roles:/usr/share/one/oneprovision/ansible/roles:/var/lib/one/.an sible/roles:/var/lib/one/.ansible/ceph-7.0/roles:/usr/share/one/oneprovision/ansible/ceph_hci
The error appears to be in ‘/usr/share/one/oneprovision/ansible/ceph_hci/site.yml’: line 12, column 5, but may
be elsewhere in the file depending on the exact syntax problem.
The offending line appears to be:
- role: stackhpc.systemd_networkd
^ here
2024-06-24 04:14:07 DEBUG : Command STDERR: ERROR! the role ‘stackhpc.systemd_networkd’ was not found in /usr/share/one/oneprovision/ansible/ceph_hci/roles:/usr/share/one /oneprovision/ansible/roles:/var/lib/one/.ansible/roles:/var/lib/one/.ansible/ceph-7.0/roles:/usr/share/one/oneprovision/ansible/ceph_hci
The offending line appears to be: - role: stackhpc.systemd_networkd
^ here
2024-06-24 04:14:07 WARN : Command FAILED (code=1): ANSIBLE_CONFIG=/tmp/d20240624-29146-1tn87vu/ansible.cfg ansible-playbook --ssh-common-args=‘-o UserKnownHostsFile=/de v/null’ -i /tmp/d20240624-29146-1tn87vu/inventory -i /tmp/d20240624-29146-1tn87vu/ceph_inventory.yml -e @/tmp/d20240624-29146-1tn87vu/ceph_group_vars.yml /usr/share/one /oneprovision/ansible/ceph_hci/site.yml
ERROR: Failed to configure hosts
- quit
- retry
- skip
- cleanup
Choose failover method:
Details
- Affected Component: HCI op premises
- Hypervisor: VMware
- Version: 6.8.0
