I try to find a way to change boot order in my opennebula configuration after made the machine.
I see an old version (6.2 not managed by me) which have the boot order fonction, but in 6.10 I can’t found this configuration in Sunstone.
I try with oneadmin and my admin user with all dashboard and I can’t find a way to display boot order configuration.
I check this topic but I don’t know where I set this variable. I try to add it in /etc/one/vmm_exec/vmm_exec_kvm.conf with value RAW=<bootmenu enable='yes'/> but it’s not work.
The configuration file is typically found at /etc/one/sunstone-views.yaml. Search for the features section, check the the show_boot_order attribute is set to true. Save the changes and restart the service.
