Changing the boot disk via sunstone removes CPU_MODEL from the vm configuration
OpenNebula 7.0, KVM Nodes
Edit the Configuration of a VM via “Update VM Configuration” in SunStone, go to Boot order and select any disk, click on “Accept”
the CPU_MODEL parameter gets removed from the VM configuration and needs to be re-added with onevm updateconf
change of boot order without messing up the VM configuration
Hello @twa,
Thanks for raising this issue on the category :wink:
From what I could investigate, there’s a workaround for this:
  • Modify the boot order via CLI using onevm updateconf instead of Sunstone.
  • Define CPU_MODEL in the original VM template so it is preserved during UI edits.
In any case, my suggestion would be file an issue on the OpenNebula repo:
Github Repo, so the technical team can review it better and give you a more technical reply.
Regards,
