Hmm create VDC with SATA DS
logged under user -> DataStore - and shows only two DS: SATA and System, but VM anyway created on DataStore - which is default
That will depend on the scheduler, and your VM template ds_requirements and ds_rank[quote=“Alexey_Shalin, post:6, topic:2610, full:true”]
I;m removed user from default group
[/quote]
Did you remove the new group from the default VDC?
onevdc show 101
VDC 101 INFORMATION
GROUPS
101
HOSTS
ZONE HOST
0 0
0 1
0 2
DATASTORES
ZONE DATASTORE
0 100
0 106
VNETS
ZONE VNET
0 0
VDC TEMPLATE
group 101
onegroup show 101
GROUP 101 INFORMATION
GROUP TEMPLATE
SUNSTONE=[
DEFAULT_VIEW=“user”,
GROUP_ADMIN_DEFAULT_VIEW=“groupadmin”,
GROUP_ADMIN_VIEWS=“groupadmin,cloud,admin,user”,
VIEWS=“cloud,user” ]
USER ID ADMIN
50
59
RESOURCE USAGE & QUOTAS
NUMBER OF VMS MEMORY CPU SYSTEM_DISK_SIZE
2 / - 2G / - 2.00 / - 0M / -
NETWORK ID LEASES
0 2 / -
IMAGE ID RUNNING VMS
0 1 / -
1 1 / -
user 59
oneuser show 59
USER 59 INFORMATION
GROUP : SATA
PASSWORD : 50205d58e67f05cd7c1850368d3b435141d675ad
AUTH_DRIVER : core
ENABLED : Yes
If i will login under this user - in DS i will see only 2 DS (and it’s OK)
but when i’m creating VM … it’s always creates on default DS (which was defined in IMAGE)
I just want that VM creates on DS which listed under user
