Getting "Warning: Unresponsive script" when trying to create/modify a template - OpenNebula 4.14 Beta 1
Hi all,
We are testing the OpenNebula 4.14 Beta 1 release and we are getting the following warning “Warning: Unresponsive script” when trying to create/modify a template:
 Error when trying to update the template configuration
 A script on this page may be busy, or it may have stopped responding. You can stop the script now, open the script in
 the debugger, or let the script continue.
 Script: https://test-sunstone4.oort.surfsara.nl/dist/main.js:3
I need to make click on the “stop” button several times in order to be able to update/create it. Did anyone else notice this?
Maybe, it is an issue from my side since I am still restoring/applying the current configuration that we have on production on this testbed with 4.14 beta1.
We are using Firefox 39 to access to the Sunstone UI:
firefox-39.0.3-1.fc21.x86_64
Any help/hint is welcome :smile:
Thanks in advance,
Esteban
I have the same Problem.
Mozilla Firefox 40.0
In Chromium it works without Problems.
It’s fixed in master, see: http://dev.opennebula.org/issues/3914#change-11386
And indeed, for Chromium it works fine.
Hallo Stefan,
Thank you very much for letting my know :smile:
Sorry, I did not know that there was already an open issue for tracking this issue.
Cheers,
Esteban
