Hi all,
I am am developing a system using python which makes use of opennebula. At this point I am using Apache Libcloud, and since it is compatible upto opennebula version 3.8, I am not able to use the newest opennebula. Please suggest some good methods / libraries so as I can control / access opennebula 4.0+ in python.
Try xmlrpclib and use XML-RPC API: http://docs.opennebula.org/4.10/integration/system_interfaces/api.html .
