Help with rebranding
hi
i’m looking for 2 thing in branding
one is this :
i want to change the “sunstone”
the other is, how can i hide certain tabs?
for example the storage tab.
from what i’ve seen there isn’t a formal way to do it, but i don’t mind editing files manually, i just can’t find where to replace it among all the files used by the opennebula system (version 6.8.0)
thank you
Hi @Liorme !
So the rebranding of FireEdge Sunstone isn’t available in version 6.8 unfortunately, but will be included in 6.10, which is currently under development ( FireEdge Configuration — OpenNebula 6.9.80 documentation).
As for enabling/disabling certain tabs/sections/features and so on… this can all be controlled by modifying the corresponding YAML file for that tab, you can refer to the documentation for it here ( Sunstone Views — OpenNebula 6.9.80 documentation )
Best regards,
Victor
thank you
also, where can i set additional template logos? (for fireedge)
i found the folder, but not the file that points them
Hi @Liorme
Unfortunately, the ability to customize and add different template logos in FireEdge isn’t yet supported in the same way that Ruby Sunstone does it. However this is something that we will be implementing post 6.10. I have opened a new issue for it so you can track the progress of it here.
In the meantime, a hackish solution to this would be to change the images that are being referenced in FireEdge (one/src/fireedge/src/client/constants/vmTemplate.js at master · OpenNebula/one · GitHub). You can find these referenced images at this path most likely /usr/lib/one/fireedge/src/client/assets/images/logos.
Best regards,
Victor
thank you
inside the file it looks like this
so maybe i can add rows here? or it won’t work?
meaning something like
Oracle: ‘images/logos/oracle.png’,
logo1: ‘images/logos/logo1.png’,
Yes, you can definitely make the necessary modifications to that file as well and then re-compile FireEdge in order for them to take effect. You can refer to this part of the documentation on how to compile everything from source.
In order to try things out for yourself I suggest you clone the one repo and navigate to the fireedge subdirectory and launch it in dev mode using npm run dev. Once you have this up and running, you should be able to make any modifications you need to the codebase and it will do a hot/live-reload every time you save.
P.S. This is the folder you should add the images to when testing things out in dev mode
hi. reaching out through this post. i’ve noticed that 6.10 has come out. can you point me to its rebranding options in the documentation?
Hello @Liorme,
This is an old post, and sincerely, you are not adding much information to what you specifically need.
Please check this post instead:
Or open a new one and include more information, so we can point to the right documentation page.
Cheers,
