Hi all,
can anyone describe what data are relevant in order to have Sunstone backup ready to restore when hypervisor where Sunstone is running will fail?
BR!
Hi all,
BR!
Hello @Snowman
Could you please elaborate a bit more about what do you mean by “have Sunstone backup ready”?
I am running Opennebula 5.x and I would like to know what do I have to backup in order to be able to restore Sunstone to newly installed node. I suppose it will be MySQL backend - do i.e. SQL database dump. But there will be some config files or settings related to sunstone somewhere in system.
I want to backup Sunstone in way that I will be able to restore it with data when node where SS is running will fail and data will be lost.
The Sunstone configuration files are located in /etc/one/, they are the following:
