Like the subject said I need to install windows 2003 for a legacy test. I s there any way ?
Alternatively you could slipstream the KVM virtio drivers (or whatever drivers your hypervisor uses) into the 2003 install iso using a tool such as nlite. Then you wouldn’t need to use a vfd image.
Yeah i tried nlite and it didn’t work. Any othe suggestions?
THanks
-vizo-
Never mind I had to install txt mode drivers. That worked perfectly
