Hi all!
I am new here and also new to OpenNebula. I am trying out OpenNebula to see if it’s something we can use.
However I am experiencing issues with setting up a node. The main issue I cannot seem to connect to the node from the front-end as oneadmin. No matter what I try or do…
I followed both the documentation (https://docs.opennebula.org/5.4/deployment/node_installation/kvm_node_installation.html) as this tutorial (https://computingforgeeks.com/opennebula-kvm-node-installation-centos-7/) many times. Even redid the installation several times. And I am 100% confident that I followed the documentation / tutorial to the letter. Also tried several other things.
But for some reason, I cannot connect to the node at all as user “oneadmin”. It is giving me a headache after 2 days. Setting up the front-end was easy compared to setting up a node. And the only problem is, is connecting by SSH to it.
Before I forget. SSH is working for the node; as I can connect to it by “root” without issues at all. And if I use “ssh-copy-id @” I can even login as root without password from the front-end. So I am 100% sure SSH is working and accepting connections.
I am really stumped by this. Maybe I am a complete idiot, but I have no clue what I am doing wrong, especially since I followed the documentation/tutorial to the letter. So I think there is missing a step somewhere. I have cleaned out “/var/lib/one/”-folder (on the node) several times and redid all the steps once again. But, again, with the same nasty result. No SSH connection possible/allowed/whatever as “oneadmin”. Sigh…
While I was typing this, I redid everything on the node once more (obviously with exactly the same result).
What I did (removed “/var/lib/one/”-folder before installing ofcourse) after installing “opennebula-node-kvm” and modifying /etc/libvirt/libvirtd.conf and restarting it, was the following:
Open my SSH connection to the front-end:
su - oneadmin
Result:
-bash-4.2$ -
ssh-keyscan ip-front-end ip-node >> /var/lib/one/.ssh/known_hosts
Result:
- ip-front-end:22 SSH-2.0-OpenSSH_7.4
- ip-node:22 SSH-2.0-OpenSSH_7.4
I am guessing that I now type “exit” and return as “root” on the front-end?
(if this is not correct, rest assured I tried the same from the bash as well)
- scp -rp /var/lib/one/.ssh ip-node:/var/lib/one/
Result:
id_rsa 100% 1679 78.5KB/s 00:00
id_rsa.pub 100% 406 20.7KB/s 00:00
authorized_keys 100% 406 22.2KB/s 00:00
known_hosts 100% 25KB 739.3KB/s 00:00
So far so good, I guess?
Now there is a minor different between the documentation and the tutorial, so I will use the example given in the documentation. According to the documentation:
- I opened a new SSH connection (just to be sure) to the front-end and logged in as “oneadmin” with my created password.
Result:
-bash-4.2$
So next up is: ssh
- ssh ip-node
Result:
oneadmin@ip-node’s password:
So here it already goes wrong; instead of giving me access without password, it asks for a password. Sigh.
What am I doing wrong?! Where do I have to look?! What do I have to change to make this work?! Going crazy here…
Furthermore, even if I enter the password, which I use for “oneadmin” it’s not being accepted.
Which isn’t a big surprise as there is not “oneadmin” user in /etc/passwd. So I doubt this will ever work.
Created the “oneadmin”-user manually on the node and retried the above. It still asks for a password, but when I enter it, I can login (but not without password).
So next up; trying to login from the node to the front-end (I am guessing this should be possible). I logged in as user “oneadmin” and tried to ssh to the front-end. The result:
The authenticity of host ‘ip-front-end (ip-front-end)’ can’t be established.
ECDSA key fingerprint is SHA256:uJtfvOGkCnPRsItvT4UmHaGlXXXXXX-REMOVED-XXXXX.
ECDSA key fingerprint is MD5:29:fe:76:21:84:e8:de:1b:a9:XX:XX:XX:XX:XX:XX:XX.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added ‘ip-front-end’ (ECDSA) to the list of known hosts.
oneadmin@ip-front-end’s password:
Also the other way around it asks for a password…
So, after redoing everything for 2 days in a row now and not getting anywhere, I am getting pretty annoyed by this. I was expecting this to be much, much easier. However it seems setting up a node is very, very difficult. Not only that, but I also have a headache because of this. I really have no clue what I am doing wrong, as I followed the documentation and tutorial perfectly (and redid it many times now). But all without any kind of success.
I searched the forums about similar issues in regards to SSH connecting without password and I also searched the internet with Google, but also without any result, let alone a working solution. Even tried chown, chmod and what else. To be honest; I tried so many things that I have no clue what I tried or did trying to make it work…
…yes, maybe I am an idiot and I am making a mistake somewhere, but when I follow the documentation / tutorial to the letter, it should simply work, right?
So I am hoping someone experienced can provide some insight, solution or anything that can help me in getting SSH access to the node correctly and without password.
And for your information; front-end and node were completely setup from scratch with CentOS 7.x and updated everything (as mentioned in the documentation). I even tried different versions op OpenNebula from 5.4 (yesterday) and 5.6 (today). All without any form of succes. Well that’s not completely true; the front-end appears to work, but without the possibility to connect nodes to it, it’s not much use…
Anyways, I hope I can get some help here, or at least provide me in the right direction. Thank you!!
