Microvm looking for a how to
I am trying to wrap my head around using microvm are there any examples someone can point me to of how to deploy one?
TIA
-vizo-
Hello @vizo,
We used to use Firecracker for MicroVMs, and now it has been replaced by KVM, so from our documentation, you should take a look here:
For older versions, compatible with Firecracker, you can check this article:
Ok I am using 6.10 but there is no real explanation in running a microvm it seems. I understand from my searches wouldn’t I need to download a kernel file? I am totally new to microvm, the documentation doesn’t mention it at all , like can I use the kvm host or do I add it like the old version for for firecracker? For lxc and kvm and kubernetes everything seems spelled out microvm is mentioned but I can’t find a example of using one.
