By default, minione deploys a qcow2 storage on image and system datastores. This is incompatible with firecracker. You need to user raw images.
Take a look at the following datastore and images templates for reference
root@minione-8926:~# onedatastore show 100
DATASTORE 100 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : IMAGE
DS_MAD : fs
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/100
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : 38.6G
FREE: : 34.6G
USED: : 4G
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
CLONE_TARGET="SYSTEM"
DISK_TYPE="FILE"
DS_MAD="fs"
LN_TARGET="SYSTEM"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
TM_MAD="ssh"
TYPE="IMAGE_DS"
IMAGES
3
root@minione-8926:~# onedatastore show 102
DATASTORE 102 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : SYSTEM
DS_MAD : -
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/102
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : -
FREE: : -
USED: : -
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="YES"
DISK_TYPE="FILE"
DS_MIGRATE="YES"
RESTRICTED_DIRS="/"
SHARED="NO"
TM_MAD="ssh"
TYPE="SYSTEM_DS"
IMAGES
and the image
root@minione-8926:~# oneimage show 3
IMAGE 3 INFORMATION
USER : oneadmin
GROUP : oneadmin
LOCK : None
DATASTORE : local_raw_images
TYPE : OS
REGISTER TIME : 05/30 19:49:44
PERSISTENT : No
SOURCE : /var/lib/one//datastores/100/65810155f9903627fbd0ec4f0027b462
PATH : docker://alpine?size=2048&filesystem=ext4&format=raw
FORMAT : raw
STATE : used
RUNNING_VMS : 1
OWNER : um-
GROUP : ---
OTHER : ---
IMAGE TEMPLATE
DEV_PREFIX="vd"
FROM_APP="136"
FROM_APP_MD5="5b9de9f2756d1df622e3cbef3dedb95c"
FROM_APP_NAME="alpine"
VIRTUAL MACHINES
ID USER GROUP NAME STAT CPU MEM HOST TIME
1 oneadmin oneadmin local_raw_alpine-1 runn 1 768M localhost 0d 00h05
And the resulting VMs
root@minione-8926:~# onevm list
1 oneadmin oneadmin local_raw_alpine-1 runn 1 768M localhost 0d 00h06
0 oneadmin oneadmin alpine_dh_fc-0 poff 1 768M localhost 0d 00h18
VM 0 is deployed as you did and it results in the same error
root@minione-8926:~# cat /var/lib/one/datastores/0/0/logs.fifo
Running Firecracker v0.24.2
2023-05-30T19:40:42.437249538 [one-0:main] Disk size 196648 is not a multiple of sector size 512; the remainder will not be visible to the guest.
2023-05-30T19:40:42.486825520 [one-0:main] Artificially kick devices.
2023-05-30T19:40:42.486865428 [one-0:main] kick block disk.0.
2023-05-30T19:40:42.486874038 [one-0:main] kick block disk.1.
2023-05-30T19:40:42.499816746 [one-0:main] Successfully started microvm that was configured from one single json
2023-05-30T19:40:43.476946456 [one-0:main] block: activate event
2023-05-30T19:40:43.483353404 [one-0:main] block: activate event
2023-05-30T19:40:44.597997155 [one-0:main] Vmm is stopping.
in the case of VM 1 you get this log
root@minione-8926:~# cat /var/lib/one/datastores/102/1/logs.fifo
2023-05-30T19:53:04.176785019 [one-1:main] Disk size 2147483842 is not a multiple of sector size 512; the remainder will not be visible to the guest.
2023-05-30T19:53:04.234149224 [one-1:main] Artificially kick devices.
2023-05-30T19:53:04.234174253 [one-1:main] kick block disk.0.
2023-05-30T19:53:04.234178234 [one-1:main] kick block disk.1.
2023-05-30T19:53:04.234603368 [one-1:main] Successfully started microvm that was configured from one single json
2023-05-30T19:53:04.950343532 [one-1:main] block: activate event
2023-05-30T19:53:04.954820766 [one-1:main] block: activate event
2023-05-30T19:53:04.964602534 [one-1:fc_vcpu 0] Failed to trigger i8042 kbd interrupt (disabled by guest OS)
2023-05-30T19:53:04.981184930 [one-1:fc_vcpu 0] Failed to trigger i8042 kbd interrupt (disabled by guest OS)
2023-05-30T19:53:07.002527637 [one-1:fc_api] The API server received a Get request on "/machine-config".
2023-05-30T19:53:07.002561896 [one-1:fc_api] The request was executed successfully. Status code: 200 OK.
2023-05-30T19:53:07.002569096 [one-1:fc_api] Total previous API call duration: 46 us.
2023-05-30T19:53:07.002741299 [one-1:fc_api] The API server received a Get request on "/".
2023-05-30T19:53:07.002748559 [one-1:fc_api] Total previous API call duration: 9 us.
2023-05-30T19:53:12.165674659 [one-1:fc_api] The API server received a Get request on "/machine-config".
2023-05-30T19:53:12.165721197 [one-1:fc_api] The request was executed successfully. Status code: 200 OK.
2023-05-30T19:53:12.165728497 [one-1:fc_api] Total previous API call duration: 58 us.
2023-05-30T19:53:12.165935239 [one-1:fc_api] The API server received a Get request on "/".
2023-05-30T19:53:12.165946610 [one-1:fc_api] Total previous API call duration: 13 us.
2023-05-30T19:53:15.679059323 [one-1:fc_api] The API server received a Get request on "/machine-config".
2023-05-30T19:53:15.679129841 [one-1:fc_api] The request was executed successfully. Status code: 200 OK.
2023-05-30T19:53:15.679143860 [one-1:fc_api] Total previous API call duration: 91 us.
2023-05-30T19:53:15.679596384 [one-1:fc_api] The API server received a Get request on "/".
2023-05-30T19:53:15.679619842 [one-1:fc_api] Total previous API call duration: 27 us.
2023-05-30T19:53:17.319156745 [one-1:fc_api] The API server received a Get request on "/machine-config".
2023-05-30T19:53:17.319197533 [one-1:fc_api] The request was executed successfully. Status code: 200 OK.
and the VM attach process running with no issues
root@minione-8926:~# ps aux | grep -i screen
oneadmin 50255 0.0 0.1 8704 2324 ? Ss 19:53 0:00 SCREEN -dmS one-1 sudo -n jailer --id one-1 --node 0 --exec-file /usr/bin/firecracker --uid 9869 --gid 9869 -- --config-file deployment.file
root 53015 0.0 0.1 8156 2564 pts/0 S+ 20:01 0:00 grep --color=auto -i screen
As you can see, deploying minione with firecracker requires some extra steps due to the limitations and additional setup required. Enabling minione --firecracker means also supporting such deployment. Since the goal of minione is to quickly try out OpenNebula, we decided to drop the firecracker deployment mode a while ago.
This being said, if you want to quickly try out OpenNebula with firecracker, it would have come handy. If you think this is a good feature to have, please open a request on the minione repository. LXC support was added as well after FireCracker and LXD were dropped.
