Not able to open port 2633
I am doing a fresh installation and after starting opennebula for the first time I get the following error:
Cannot contact oned, will retry… Error: HTTP POST to URL ‘http://localhost:2633/RPC2’ failed. libcurl failed even to execute the HTTP transaction, explaining: Failed connect to localhost:2633; Connection refused
how to open the port?
In the search field on this forum search for “Failed connect to localhost:2633” and get familiar with the existing threads, e.g. https://forum.opennebula.io/t/failed-connect-to-localhost-2633-connection-refused/, but there are more threads that mention this error.
Describe the solution you found, or provide below the troubleshooting details mentioned in the other threads.
I did try both the threads but none of the solutions work for me.
https://forum.opennebula.io/t/failed-to-open-tcp-connection-to-localhost-2633-connection-refused-connect-2-for-localhost-port-2633/ shows basic troubleshooting steps:
sudo su - -c ‘netstat -ntlp’
sudo su - -c ‘systemctl status opennebula’
sudo su - -c ‘systemctl restart opennebula’
and looking at the logs /var/log/one/oend.log + the system logs the location of the which depends on the OS.
What is the outcome of these steps? What is the OS, opennebula version?
It is the same. I am installing 5.4 in centOS
Can you show us your log file??
This is sched log
oned.log-20180403-1522750681 (8.4 KB)
And I have attached the oned.log file. Let me know if you need any other
Have you changed the db configuration in oned.conf file.??
Like this
Sample configuration for MySQL
DB = [ BACKEND = “mysql”,
SERVER = “localhost”,
PORT = 0,
USER = “oneadmin”,
PASSWD = “oneadmin”,
DB_NAME = “opennebula” ]
Yes. I am copying the oned.conf file. Please check it and let me know if I am missing something else
OpenNebula Configuration file
Daemon configuration attributes
MANAGER_TIMER: Time in seconds the core uses to evaluate periodical functions.
MONITORING_INTERVAL cannot have a smaller value than MANAGER_TIMER.
MONITORING_INTERVAL: Time in seconds between host and VM monitorization.
MONITORING_THREADS: Max. number of threads used to process monitor messages
HOST_PER_INTERVAL: Number of hosts monitored in each interval.
HOST_MONITORING_EXPIRATION_TIME: Time, in seconds, to expire monitoring
information. Use 0 to disable HOST monitoring recording.
VM_INDIVIDUAL_MONITORING: VM monitoring information is obtained along with the
host information. For some custom monitor drivers you may need activate the
individual VM monitoring process.
VM_PER_INTERVAL: Number of VMs monitored in each interval, if the individual
VM monitoring is set to yes.
VM_MONITORING_EXPIRATION_TIME: Time, in seconds, to expire monitoring
information. Use 0 to disable VM monitoring recording.
SCRIPTS_REMOTE_DIR: Remote path to store the monitoring and VM management
scripts.
PORT: Port where oned will listen for xmlrpc calls.
LISTEN_ADDRESS: Host IP to listen on for xmlrpc calls (default: all IPs).
DB: Configuration attributes for the database backend
backend : can be sqlite or mysql (default is sqlite)
server : (mysql) host name or an IP address for the MySQL server
port : (mysql) port for the connection to the server.
If set to 0, the default port is used.
user : (mysql) user’s MySQL login ID
passwd : (mysql) the password for user
db_name : (mysql) the database name
VNC_PORTS: VNC port pool for automatic VNC port assignment, if possible the
port will be set to START + VMID
start : first port to assign
reserved: comma separated list of ports or ranges. Two numbers separated by
a colon indicate a range.
LOG: Configuration for the logging system
system: defines the logging system:
file to log in the oned.log file
syslog to use the syslog facilities
std to use the default log stream (stderr) to use with systemd
debug_level: 0 = ERROR, 1 = WARNING, 2 = INFO, 3 = DEBUG
VM_SUBMIT_ON_HOLD: Forces VMs to be created on hold state instead of pending.
Values: YES or NO.
LOG = [
SYSTEM = “file”,
DEBUG_LEVEL = 3
#MANAGER_TIMER = 15
MONITORING_INTERVAL = 60
MONITORING_THREADS = 50
#HOST_PER_INTERVAL = 15
#HOST_MONITORING_EXPIRATION_TIME = 43200
#VM_INDIVIDUAL_MONITORING = “no”
#VM_PER_INTERVAL = 5
#VM_MONITORING_EXPIRATION_TIME = 14400
SCRIPTS_REMOTE_DIR=/var/tmp/one
PORT = 2633
LISTEN_ADDRESS = “0.0.0.0”
#DB = [ BACKEND = “sqlite” ]
PORT = 0,
USER = “oneadmin”,
VNC_PORTS = [
START = 5900
RESERVED = “6800, 6801, 6810:6820, 9869”
#VM_SUBMIT_ON_HOLD = “NO”
Federation & HA configuration attributes
Control the federation capabilities of oned. Operation in a federated setup
requires a special DB configuration.
FEDERATION: Federation attributes
MODE: Operation mode of this oned.
STANDALONE no federated.This is the default operational mode
MASTER this oned is the master zone of the federation
SLAVE this oned is a slave zone
ZONE_ID: The zone ID as returned by onezone command
SERVER_ID: ID identifying this server in the zone as returned by the
onezone server-add command. This ID controls the HA configuration of
OpenNebula:
-1 (default) OpenNebula will operate in “solo” mode no HA
Operate in HA (leader election and state replication)
MASTER_ONED: The xml-rpc endpoint of the master oned, e.g.
http://master.one.org:2633/RPC2
RAFT: Algorithm attributes
LOG_RETENTION: Number of DB log records kept, it determines the
synchronization window across servers and extra storage space needed.
LOG_PURGE_TIMEOUT: How often applied records are purged according the log
retention value. (in seconds)
ELECTION_TIMEOUT_MS: Timeout to start a election process if no heartbeat
or log is received from leader.
BROADCAST_TIMEOUT_MS: How often heartbeats are sent to followers.
XMLRPC_TIMEOUT_MS: To timeout raft related API calls
RAFT_LEADER_HOOK: Executed when a server transits from follower->leader
The purpose of this hook is to configure the Virtual IP.
COMMAND: raft/vip.sh is a fully working script, this should not be changed
ARGUMENTS: and <ip_cidr> must be replaced. For example
ARGUMENTS = “leader ens1 10.0.0.2/24”
RAFT_FOLLOWER_HOOK: Executed when a server transits from leader->follower
ARGUMENTS = “follower ens1 10.0.0.2/24”
NOTE: Timeout tunning depends on the latency of the servers (network and load)
as well as the max downtime tolerated by the system. Timeouts needs to be
greater than 10ms
FEDERATION = [
MODE = “STANDALONE”,
ZONE_ID = 0,
SERVER_ID = 1,
MASTER_ONED = “”
RAFT = [
LOG_RETENTION = 500000,
LOG_PURGE_TIMEOUT = 600,
ELECTION_TIMEOUT_MS = 5000,
BROADCAST_TIMEOUT_MS = 500,
XMLRPC_TIMEOUT_MS = 0
RAFT_LEADER_HOOK = [
COMMAND = “raft/vip.sh”,
ARGUMENTS = “leader <ip_cidr>”
RAFT_FOLLOWER_HOOK = [
ARGUMENTS = “follower <ip_cidr>”
Default showback cost
The following attributes define the default cost for Virtual Machines that
don’t have a CPU, MEMORY or DISK cost. This is used by the oneshowback
calculate method.
DEFAULT_COST = [
CPU_COST = 0,
MEMORY_COST = 0,
DISK_COST = 0
XML-RPC server configuration
These are configuration parameters for oned’s xmlrpc-c server
MAX_CONN: Maximum number of simultaneous TCP connections the server
will maintain
MAX_CONN_BACKLOG: Maximum number of TCP connections the operating system
will accept on the server’s behalf without the server accepting them from
KEEPALIVE_TIMEOUT: Maximum time in seconds that the server allows a
connection to be open between RPCs
KEEPALIVE_MAX_CONN: Maximum number of RPCs that the server will execute on
a single connection
TIMEOUT: Maximum time in seconds the server will wait for the client to
do anything while processing an RPC. This timeout will be also used when
proxy calls to the master in a federation.
RPC_LOG: Create a separated log file for xml-rpc requests, in
“/var/log/one/one_xmlrpc.log”.
MESSAGE_SIZE: Buffer size in bytes for XML-RPC responses.
LOG_CALL_FORMAT: Format string to log XML-RPC calls. Interpreted strings:
%i – request id
%m – method name
%u – user id
%U – user name
%l – param list
%p – user password
%g – group id
%G – group name
%a – auth token
#MAX_CONN = 15
#MAX_CONN_BACKLOG = 15
#KEEPALIVE_TIMEOUT = 15
#KEEPALIVE_MAX_CONN = 30
#TIMEOUT = 15
#RPC_LOG = NO
#MESSAGE_SIZE = 1073741824
#LOG_CALL_FORMAT = “Req:%i UID:%u %m invoked %l”
Physical Networks configuration
NETWORK_SIZE: Here you can define the default size for the virtual networks
MAC_PREFIX: Default MAC prefix to be used to create the auto-generated MAC
addresses is defined here (this can be overwritten by the Virtual Network
template)
VLAN_IDS: VLAN ID pool for the automatic VLAN_ID assignment. This pool
is for 802.1Q networks (Open vSwitch and 802.1Q drivers). The driver
will try first to allocate VLAN_IDS[START] + VNET_ID
start: First VLAN_ID to use
reserved: Comma separated list of VLAN_IDs or ranges. Two numbers
separated by a colon indicate a range.
VXLAN_IDS: Automatic VXLAN Network ID (VNI) assignment. This is used
for vxlan networks.
start: First VNI to use
NOTE: reserved is not supported by this pool
PCI_PASSTHROUGH_BUS: Default bus to attach passthrough devices in the guest,
in hex notation. It may be overwritten in the PCI device using the BUS
attribute.
NETWORK_SIZE = 254
MAC_PREFIX = “02:00”
VLAN_IDS = [
START = “2”,
RESERVED = “0, 1, 4095”
VXLAN_IDS = [
START = “2”
#PCI_PASSTHROUGH_BUS = “0x01”
DataStore Configuration
DATASTORE_LOCATION: Path for Datastores. It IS the same for all the hosts
and front-end. It defaults to /var/lib/one/datastores (in self-contained mode
defaults to $ONE_LOCATION/var/datastores). Each datastore has its own
directory (called BASE_PATH) in the form: $DATASTORE_LOCATION/<datastore_id>
You can symlink this directory to any other path if needed. BASE_PATH is
generated from this attribute each time oned is started.
DATASTORE_CAPACITY_CHECK: Checks that there is enough capacity before
creating a new image. Defaults to Yes
DEFAULT_IMAGE_TYPE: This can take values
OS Image file holding an operating system
CDROM Image file holding a CDROM
DATABLOCK Image file holding a datablock, created as an empty block
DEFAULT_DEVICE_PREFIX: This can be set to
hd IDE prefix
sd SCSI
vd KVM virtual disk
DEFAULT_CDROM_DEVICE_PREFIX: Same as above but for CDROM devices.
DEFAULT_IMAGE_PERSISTENT: Control the default value for the PERSISTENT
attribute on image creation (oneimage clone, onevm disk-saveas). If blank
images will inherit the persistent attribute from the base image.
DEFAULT_IMAGE_PERSISTENT_NEW: Control the default value for the PERSISTENT
attribute on image creation (oneimage create). By default images are no
persistent if not set.
#DATASTORE_LOCATION = /var/lib/one/datastores
DATASTORE_CAPACITY_CHECK = “yes”
DEFAULT_DEVICE_PREFIX = “vd”
DEFAULT_CDROM_DEVICE_PREFIX = “hd”
DEFAULT_IMAGE_TYPE = “OS”
#DEFAULT_IMAGE_PERSISTENT = “”
#DEFAULT_IMAGE_PERSISTENT_NEW = “”
Information Driver Configuration
You can add more information managers with different configurations but make
sure it has different names.
name : name for this information manager
executable: path of the information driver executable, can be an
absolute path or relative to $ONE_LOCATION/lib/mads (or
/usr/lib/one/mads/ if OpenNebula was installed in /)
arguments : for the driver executable, usually a probe configuration file,
can be an absolute path or relative to $ONE_LOCATION/etc (or
/etc/one/ if OpenNebula was installed in /)
Information Collector for KVM IM’s.
This driver CANNOT BE ASSIGNED TO A HOST, and needs to be used with KVM
-h prints this help.
-a Address to bind the collectd socket (default 0.0.0.0)
-p UDP port to listen for monitor information (default 4124)
-f Interval in seconds to flush collected information (default 5)
-t Number of threads for the server (default 50)
-i Time in seconds of the monitorization push cycle. This parameter must
be smaller than MONITORING_INTERVAL, otherwise push monitorization will
not be effective.
-w Timeout in seconds to execute external commands (default unlimited)
IM_MAD = [
NAME = “collectd”,
EXECUTABLE = “collectd”,
ARGUMENTS = “-p 4124 -f 5 -t 50 -i 20” ]
KVM UDP-push Information Driver Manager Configuration
-r number of retries when monitoring a host
-t number of threads, i.e. number of hosts monitored at the same time
IM_MAD = [
NAME = “kvm”,
SUNSTONE_NAME = “KVM”,
EXECUTABLE = “one_im_ssh”,
ARGUMENTS = “-r 3 -t 15 kvm” ]
KVM SSH-pull Information Driver Manager Configuration
IM_MAD = [
NAME = “kvm”,
SUNSTONE_NAME = “kvm-ssh”,
ARGUMENTS = “-r 3 -t 15 kvm-probes” ]
vCenter Information Driver Manager Configuration
IM_MAD = [
NAME = “vcenter”,
SUNSTONE_NAME = “VMWare vCenter”,
EXECUTABLE = “one_im_sh”,
ARGUMENTS = “-c -t 15 -r 0 vcenter” ]
EC2 Information Driver Manager Configuration
#IM_MAD = [
NAME = “ec2”,
SUNSTONE_NAME = “Amazon EC2”,
ARGUMENTS = “-c -t 1 -r 0 -w 600 ec2” ]
Azure Information Driver Manager Configuration
#IM_MAD = [
NAME = “az”,
SUNSTONE_NAME = “Microsoft Azure”,
ARGUMENTS = “-c -t 1 -r 0 az” ]
Dummy Information Driver Manager Configuration
#IM_MAD = [ NAME=“dummy”, SUNSTONE_NAME=“Testing”, EXECUTABLE=“one_im_dummy”]
Virtualization Driver Configuration
You can add more virtualization managers with different configurations but
make sure it has different names.
name : name of the virtual machine manager driver
executable: path of the virtualization driver executable, can be an
default : default values and configuration parameters for the driver, can
type : driver type, supported drivers: xen, kvm, xml
keep_snapshots: do not remove snapshots on power on/off cycles and live
migrations if the hypervisor supports that.
imported_vms_actions : comma-separated list of actions supported
for imported vms. The available actions are:
migrate
live-migrate
terminate
terminate-hard
undeploy
undeploy-hard
hold
release
stop
suspend
resume
delete
delete-recreate
reboot
reboot-hard
resched
unresched
poweroff
poweroff-hard
disk-attach
disk-detach
nic-attach
nic-detach
snap-create
snap-delete
KVM Virtualization Driver Manager Configuration
-l <actions[=command_name]> actions executed locally, command can be
overridden for each action.
Valid actions: deploy, shutdown, cancel, save, restore, migrate, poll
An example: “-l migrate=migrate_local,save”
-p more than one action per host in parallel, needs support from hypervisor
-s to execute remote commands, bash by default
Note: You can use type = “qemu” to use qemu emulated guests, e.g. if your
CPU does not have virtualization extensions or use nested Qemu-KVM hosts
VM_MAD = [
NAME = “kvm”,
EXECUTABLE = “one_vmm_exec”,
ARGUMENTS = “-t 15 -r 0 kvm”,
DEFAULT = “vmm_exec/vmm_exec_kvm.conf”,
TYPE = “kvm”,
KEEP_SNAPSHOTS = “no”,
IMPORTED_VMS_ACTIONS = “terminate, terminate-hard, hold, release, suspend,
resume, delete, reboot, reboot-hard, resched, unresched, disk-attach,
disk-detach, nic-attach, nic-detach, snap-create, snap-delete”
vCenter Virtualization Driver Manager Configuration
-s to execute commands, bash by default
-d default snapshot strategy. It can be either ‘detach’ or ‘suspend’. It
defaults to ‘suspend’.
VM_MAD = [
NAME = “vcenter”,
EXECUTABLE = “one_vmm_sh”,
ARGUMENTS = “-p -t 15 -r 0 vcenter -s sh”,
DEFAULT = “vmm_exec/vmm_exec_vcenter.conf”,
TYPE = “xml”,
KEEP_SNAPSHOTS = “yes”,
resume, delete, reboot, reboot-hard, resched, unresched, poweroff,
poweroff-hard, disk-attach, disk-detach, nic-attach, nic-detach,
EC2 Virtualization Driver Manager Configuration
-t number of threads, i.e. number of actions performed at the same time
#VM_MAD = [
NAME = “ec2”,
ARGUMENTS = “-t 15 -r 0 -w 600 -p ec2”,
TYPE = “xml”,
IMPORTED_VMS_ACTIONS = "terminate, terminate-hard, hold, release, suspend,
snap-create, snap-delete"
Azure Virtualization Driver Manager Configuration
#VM_MAD = [
NAME = “az”,
ARGUMENTS = “-t 15 -r 0 az”,
TYPE = “xml”,
Dummy Virtualization Driver Configuration
#VM_MAD = [ NAME=“dummy”, SUNSTONE_NAME=“Testing”, EXECUTABLE=“one_vmm_dummy”,
TYPE=“xml” ]
Transfer Manager Driver Configuration
You can add more transfer managers with different configurations but make
name : name for this transfer driver
executable: path of the transfer driver executable, can be an
arguments :
-t: number of threads, i.e. number of transfers made at the same time
-d: list of transfer drivers separated by commas, if not defined all the
drivers available will be enabled
-w: Timeout in seconds to execute external commands (default unlimited)
TM_MAD = [
EXECUTABLE = “one_tm”,
ARGUMENTS = “-t 15 -d dummy,lvm,shared,fs_lvm,qcow2,ssh,ceph,dev,vcenter,iscsi_libvirt”
Datastore Driver Configuration
Drivers to manage the datastores, specialized for the storage backend
-t number of threads, i.e. number of repo operations at the same time
-d datastore mads separated by commas
-s system datastore tm drivers, used to monitor shared system ds.
DATASTORE_MAD = [
EXECUTABLE = “one_datastore”,
ARGUMENTS = “-t 15 -d dummy,fs,lvm,ceph,dev,iscsi_libvirt,vcenter -s shared,ssh,ceph,fs_lvm,qcow2,vcenter”
Marketplace Driver Configuration
Drivers to manage different marketplaces, specialized for the storage backend
-m marketplace mads separated by commas
–proxy proxy address if required to access the internet
MARKET_MAD = [
EXECUTABLE = “one_market”,
ARGUMENTS = “-t 15 -m http,s3,one”
IPAM Driver Configuration
Drivers to manage different IPAMs
executable: path of the IPAM driver executable, can be an
-t number of threads, i.e. number of operations at the same time
-i IPAM mads separated by commas
IPAM_MAD = [
EXECUTABLE = “one_ipam”,
ARGUMENTS = “-t 1 -i dummy”
Hook Manager Configuration
The Driver (HM_MAD)
Used to execute the Hooks:
executable: path of the hook driver executable, can be an
arguments : for the driver executable, can be an absolute path or relative
to $ONE_LOCATION/etc (or /etc/one/ if OpenNebula was installed
in /)
Virtual Machine Hooks (VM_HOOK)
Defined by:
name : for the hook, useful to track the hook (OPTIONAL)
on : when the hook should be executed,
- CREATE, when the VM is created (onevm create)
- PROLOG, when the VM is in the prolog state
- RUNNING, after the VM is successfully booted
- UNKNOWN, when the VM is in the unknown state
- SHUTDOWN, after the VM is shutdown
- STOP, after the VM is stopped (including VM image transfers)
- DONE, after the VM is deleted or shutdown
- CUSTOM, user defined specific STATE and LCM_STATE combination
of states to trigger the hook.
command : path is relative to $ONE_LOCATION/var/remotes/hook
(self-contained) or to /var/lib/one/remotes/hook (system-wide).
That directory will be copied on the hosts under
SCRIPTS_REMOTE_DIR. It can be an absolute path that must exist
on the target host
arguments : for the hook. You can access to VM information with $
- $ID, the ID of the virtual machine
- $TEMPLATE, the VM template in xml and base64 encoded
- $PREV_STATE, the previous STATE of the Virtual Machine
- $PREV_LCM_STATE, the previous LCM STATE of the Virtual Machine
remote : values,
- YES, The hook is executed in the host where the VM was
allocated
- NO, The hook is executed in the OpenNebula server (default)
Example Virtual Machine Hook
VM_HOOK = [
name = “advanced_hook”,
on = “CUSTOM”,
state = “ACTIVE”,
lcm_state = “BOOT_UNKNOWN”,
command = “log.rb”,
arguments = “$ID $PREV_STATE $PREV_LCM_STATE” ]
Host Hooks (HOST_HOOK)
Defined by:
- CREATE, when the Host is created (onehost create)
- ERROR, when the Host enters the error state
- DISABLE, when the Host is disabled
on the target host.
arguments : for the hook. You can use the following Host information:
- $ID, the ID of the host
- $TEMPLATE, the Host template in xml and base64 encoded
remote : values,
Virtual Network (VNET_HOOK)
Virtual Router (VROUTER_HOOK)
User (USER_HOOK)
Group (GROUP_HOOK)
Image (IMAGE_HOOK)
These hooks are executed when one of the referring entities are created or
removed. Each hook is defined by:
- CREATE, when the vnet is created
- REMOVE, when the vnet is removed
on the target host.
- $TEMPLATE, the vnet template in xml and base64 encoded
Please note: In a Federation, User and Group hooks can only be defined in
the master OpenNebula.
HM_MAD = [
EXECUTABLE = “one_hm” ]
#VNET_HOOK = [
name = “vcenter_net_create”,
on = “CREATE”,
command = “vcenter/create_vcenter_net.rb”,
arguments = “$ID $TEMPLATE”]
#VNET_HOOK = [
name = “vcenter_net_delete”,
on = “REMOVE”,
command = “vcenter/delete_vcenter_net.rb”,
Fault Tolerance Hooks
This hook is used to perform recovery actions when a host fails.
Script to implement host failure tolerance
One of the following modes must be chosen
-m resched VMs to another host. (Only for images in shared storage!)
-r recreate VMs running in the host. State will be lost.
-d delete VMs running in the host
Additional flags
-f resubmit suspended and powered off VMs (only for recreate)
-p avoid resubmission if host comes back after n monitoring
cycles. 0 to disable it. Default is 2.
-u disables fencing. Fencing is enabled by default. Don’t disable it
unless you are very sure about what you’re doing
#HOST_HOOK = [
NAME = “error”,
ON = “ERROR”,
COMMAND = “ft/host_error.rb”,
ARGUMENTS = “$ID -m -p 5”,
REMOTE = “no” ]
Auth Manager Configuration
AUTH_MAD: The Driver that will be used to authenticate (authn) and
authorize (authz) OpenNebula requests. If defined OpenNebula will use the
built-in auth policies.
executable: path of the auth driver executable, can be an
authn : list of authentication modules separated by commas, if not
defined all the modules available will be enabled
authz : list of authentication modules separated by commas
DEFAULT_AUTH: The default authentication driver to use when OpenNebula does
not know the user and needs to authenticate it externally. If you want to
use “default” (not recommended, but supported for backwards compatibility
reasons) make sure you create a symlink pointing to the actual authentication
driver in /var/lib/one/remotes/auth, and add “default” to the ‘auth’
parameter in the ‘AUTH_MAD’ section.
SESSION_EXPIRATION_TIME: Time in seconds to keep an authenticated token as
valid. During this time, the driver is not used. Use 0 to disable session
caching
ENABLE_OTHER_PERMISSIONS: Whether or not users can set the permissions for
‘other’, so publishing or sharing resources with others. Users in the oneadmin
group will still be able to change these permissions. Values: YES or NO.
DEFAULT_UMASK: Similar to Unix umask, sets the default resources permissions.
Its format must be 3 octal digits. For example a umask of 137 will set
the new object’s permissions to 640 “um- u-- —”
AUTH_MAD = [
EXECUTABLE = “one_auth_mad”,
AUTHN = “ssh,x509,ldap,server_cipher,server_x509”
#DEFAULT_AUTH = “default”
SESSION_EXPIRATION_TIME = 900
#ENABLE_OTHER_PERMISSIONS = “YES”
DEFAULT_UMASK = 177
OneGate
ONEGATE_ENDPOINT: The URL for the onegate server (the Gate to OpenNebula for
VMs). The onegate server is started using a separate command. The endpoint
MUST be consistent with the values in onegate-server.conf
ONEGATE_ENDPOINT = “http://172.23.16.47:5030
VM Operations Permissions
The following parameters define the operations associated to the ADMIN,
MANAGE and USE permissions. Note that some VM operations require additional
permissions on other objects. Also some operations refers to a class of
actions:
- disk-snapshot, includes create, delete and revert actions
- disk-attach, includes attach and detach actions
- nic-attach, includes attach and detach actions
- snapshot, includes create, delete and revert actions
- resched, includes resched and unresched actions
VM_ADMIN_OPERATIONS = “migrate, delete, recover, retry, deploy, resched”
VM_MANAGE_OPERATIONS = “undeploy, hold, release, stop, suspend, resume, reboot,
poweroff, disk-attach, nic-attach, disk-snapshot, terminate, disk-resize,
snapshot, updateconf, rename, resize, update, disk-saveas”
VM_USE_OPERATIONS = “”
Restricted Attributes Configuration
The following attributes are restricted to users outside the oneadmin group
VM_RESTRICTED_ATTR = “CONTEXT/FILES”
VM_RESTRICTED_ATTR = “NIC/MAC”
VM_RESTRICTED_ATTR = “NIC/VLAN_ID”
VM_RESTRICTED_ATTR = “NIC/BRIDGE”
#VM_RESTRICTED_ATTR = “NIC/INBOUND_AVG_BW”
#VM_RESTRICTED_ATTR = “NIC/INBOUND_PEAK_BW”
#VM_RESTRICTED_ATTR = “NIC/INBOUND_PEAK_KB”
#VM_RESTRICTED_ATTR = “NIC/OUTBOUND_AVG_BW”
#VM_RESTRICTED_ATTR = “NIC/OUTBOUND_PEAK_BW”
#VM_RESTRICTED_ATTR = “NIC/OUTBOUND_PEAK_KB”
#VM_RESTRICTED_ATTR = “NIC/OPENNEBULA_MANAGED”
#VM_RESTRICTED_ATTR = “NIC/VCENTER_INSTANCE_ID”
#VM_RESTRICTED_ATTR = “NIC/VCENTER_NET_REF”
#VM_RESTRICTED_ATTR = “NIC/VCENTER_PORTGROUP_TYPE”
VM_RESTRICTED_ATTR = “NIC_DEFAULT/MAC”
VM_RESTRICTED_ATTR = “NIC_DEFAULT/VLAN_ID”
VM_RESTRICTED_ATTR = “NIC_DEFAULT/BRIDGE”
#VM_RESTRICTED_ATTR = “DISK/TOTAL_BYTES_SEC”
#VM_RESTRICTED_ATTR = “DISK/READ_BYTES_SEC”
#VM_RESTRICTED_ATTR = “DISK/WRITE_BYTES_SEC”
#VM_RESTRICTED_ATTR = “DISK/TOTAL_IOPS_SEC”
#VM_RESTRICTED_ATTR = “DISK/READ_IOPS_SEC”
#VM_RESTRICTED_ATTR = “DISK/WRITE_IOPS_SEC”
#VM_RESTRICTED_ATTR = “DISK/OPENNEBULA_MANAGED”
#VM_RESTRICTED_ATTR = “DISK/VCENTER_DS_REF”
#VM_RESTRICTED_ATTR = “DISK/VCENTER_INSTANCE_ID”
#VM_RESTRICTED_ATTR = “DISK/SIZE”
#VM_RESTRICTED_ATTR = “DISK/ORIGINAL_SIZE”
#VM_RESTRICTED_ATTR = “DISK/SIZE_PREV”
VM_RESTRICTED_ATTR = “CPU_COST”
VM_RESTRICTED_ATTR = “MEMORY_COST”
VM_RESTRICTED_ATTR = “DISK_COST”
VM_RESTRICTED_ATTR = “PCI”
VM_RESTRICTED_ATTR = “EMULATOR”
VM_RESTRICTED_ATTR = “RAW”
VM_RESTRICTED_ATTR = “USER_PRIORITY”
#VM_RESTRICTED_ATTR = “USER_INPUTS/CPU”
#VM_RESTRICTED_ATTR = “USER_INPUTS/MEMORY”
#VM_RESTRICTED_ATTR = “USER_INPUTS/VCPU”
#VM_RESTRICTED_ATTR = “TEMPLATE/VCENTER_VM_FOLDER”
#VM_RESTRICTED_ATTR = “RANK”
#VM_RESTRICTED_ATTR = “SCHED_RANK”
#VM_RESTRICTED_ATTR = “REQUIREMENTS”
#VM_RESTRICTED_ATTR = “SCHED_REQUIREMENTS”
IMAGE_RESTRICTED_ATTR = “SOURCE”
#IMAGE_RESTRICTED_ATTR = “TEMPLATE/VCENTER_IMPORTED”
The following restricted attributes only apply to VNets that are a reservation.
Normal VNets do not have restricted attributes.
VNET_RESTRICTED_ATTR = “VN_MAD”
VNET_RESTRICTED_ATTR = “PHYDEV”
VNET_RESTRICTED_ATTR = “VLAN_ID”
VNET_RESTRICTED_ATTR = “BRIDGE”
VNET_RESTRICTED_ATTR = “CONF”
VNET_RESTRICTED_ATTR = “BRIDGE_CONF”
VNET_RESTRICTED_ATTR = “IP_LINK_CONF”
VNET_RESTRICTED_ATTR = “AR/VN_MAD”
VNET_RESTRICTED_ATTR = “AR/PHYDEV”
VNET_RESTRICTED_ATTR = “AR/VLAN_ID”
VNET_RESTRICTED_ATTR = “AR/BRIDGE”
Inherited Attributes Configuration
The following attributes will be copied from the resource template to the
instantiated VMs. More than one attribute can be defined.
INHERIT_IMAGE_ATTR: Attribute to be copied from the Image template
to each VM/DISK.
INHERIT_DATASTORE_ATTR: Attribute to be copied from the Datastore template
to each VM/DISK.
INHERIT_VNET_ATTR: Attribute to be copied from the Network template
to each VM/NIC.
#INHERIT_IMAGE_ATTR = “EXAMPLE”
#INHERIT_IMAGE_ATTR = “SECOND_EXAMPLE”
#INHERIT_DATASTORE_ATTR = “COLOR”
#INHERIT_VNET_ATTR = “BANDWIDTH_THROTTLING”
INHERIT_DATASTORE_ATTR = “CEPH_HOST”
INHERIT_DATASTORE_ATTR = “CEPH_SECRET”
INHERIT_DATASTORE_ATTR = “CEPH_KEY”
INHERIT_DATASTORE_ATTR = “CEPH_USER”
INHERIT_DATASTORE_ATTR = “CEPH_CONF”
INHERIT_DATASTORE_ATTR = “POOL_NAME”
INHERIT_DATASTORE_ATTR = “ISCSI_USER”
INHERIT_DATASTORE_ATTR = “ISCSI_USAGE”
INHERIT_DATASTORE_ATTR = “ISCSI_HOST”
INHERIT_IMAGE_ATTR = “ISCSI_USER”
INHERIT_IMAGE_ATTR = “ISCSI_USAGE”
INHERIT_IMAGE_ATTR = “ISCSI_HOST”
INHERIT_IMAGE_ATTR = “ISCSI_IQN”
INHERIT_DATASTORE_ATTR = “GLUSTER_HOST”
INHERIT_DATASTORE_ATTR = “GLUSTER_VOLUME”
INHERIT_DATASTORE_ATTR = “DISK_TYPE”
INHERIT_DATASTORE_ATTR = “ALLOW_ORPHANS”
INHERIT_DATASTORE_ATTR = “VCENTER_ADAPTER_TYPE”
INHERIT_DATASTORE_ATTR = “VCENTER_DISK_TYPE”
INHERIT_DATASTORE_ATTR = “VCENTER_DS_REF”
INHERIT_DATASTORE_ATTR = “VCENTER_DS_IMAGE_DIR”
INHERIT_DATASTORE_ATTR = “VCENTER_DS_VOLATILE_DIR”
INHERIT_DATASTORE_ATTR = “VCENTER_INSTANCE_ID”
INHERIT_IMAGE_ATTR = “DISK_TYPE”
INHERIT_IMAGE_ATTR = “VCENTER_ADAPTER_TYPE”
INHERIT_IMAGE_ATTR = “VCENTER_DISK_TYPE”
INHERIT_VNET_ATTR = “VLAN_TAGGED_ID”
INHERIT_VNET_ATTR = “FILTER_IP_SPOOFING”
INHERIT_VNET_ATTR = “FILTER_MAC_SPOOFING”
INHERIT_VNET_ATTR = “MTU”
INHERIT_VNET_ATTR = “INBOUND_AVG_BW”
INHERIT_VNET_ATTR = “INBOUND_PEAK_BW”
INHERIT_VNET_ATTR = “INBOUND_PEAK_KB”
INHERIT_VNET_ATTR = “OUTBOUND_AVG_BW”
INHERIT_VNET_ATTR = “OUTBOUND_PEAK_BW”
INHERIT_VNET_ATTR = “OUTBOUND_PEAK_KB”
INHERIT_VNET_ATTR = “CONF”
INHERIT_VNET_ATTR = “BRIDGE_CONF”
INHERIT_VNET_ATTR = “IP_LINK_CONF”
INHERIT_VNET_ATTR = “VCENTER_NET_REF”
INHERIT_VNET_ATTR = “VCENTER_SWITCH_NAME”
INHERIT_VNET_ATTR = “VCENTER_SWITCH_NPORTS”
INHERIT_VNET_ATTR = “VCENTER_PORTGROUP_TYPE”
INHERIT_VNET_ATTR = “VCENTER_CCR_REF”
INHERIT_VNET_ATTR = “VCENTER_INSTANCE_ID”
Transfer Manager Driver Behavior Configuration
The configuration for each driver is defined in TM_MAD_CONF. These
values are used when creating a new datastore and should not be modified
since they define the datastore behavior.
name : name of the transfer driver, listed in the -d option of the
TM_MAD section
ln_target : determines how the persistent images will be cloned when
a new VM is instantiated.
NONE: The image will be linked and no more storage capacity will be used
SELF: The image will be cloned in the Images datastore
SYSTEM: The image will be cloned in the System datastore
clone_target : determines how the non persistent images will be
cloned when a new VM is instantiated.
shared : determines if the storage holding the system datastore is shared
among the different hosts or not. Valid values: “yes” or “no”
ds_migrate : The driver allows migrations across datastores. Valid values:
“yes” or “no”. Note: THIS ONLY APPLIES TO SYSTEM DS.
allow_orphans: Snapshots can live without parents
TM_MAD_CONF = [
NAME = “dummy”, LN_TARGET = “NONE”, CLONE_TARGET = “SYSTEM”, SHARED = “YES”,
DS_MIGRATE = “YES”
TM_MAD_CONF = [
NAME = “lvm”, LN_TARGET = “NONE”, CLONE_TARGET = “SELF”, SHARED = “YES”
TM_MAD_CONF = [
NAME = “shared”, LN_TARGET = “NONE”, CLONE_TARGET = “SYSTEM”, SHARED = “YES”,
DS_MIGRATE = “YES”
TM_MAD_CONF = [
NAME = “fs_lvm”, LN_TARGET = “SYSTEM”, CLONE_TARGET = “SYSTEM”, SHARED=“YES”,
DRIVER = “raw”
TM_MAD_CONF = [
NAME = “qcow2”, LN_TARGET = “NONE”, CLONE_TARGET = “SYSTEM”, SHARED = “YES”,
DRIVER = “qcow2”
TM_MAD_CONF = [
NAME = “ssh”, LN_TARGET = “SYSTEM”, CLONE_TARGET = “SYSTEM”, SHARED = “NO”,
DS_MIGRATE = “YES”
TM_MAD_CONF = [
NAME = “ceph”, LN_TARGET = “NONE”, CLONE_TARGET = “SELF”, SHARED = “YES”,
DS_MIGRATE = “NO”, DRIVER = “raw”, ALLOW_ORPHANS=“yes”
TM_MAD_CONF = [
NAME = “iscsi_libvirt”, LN_TARGET = “NONE”, CLONE_TARGET = “SELF”, SHARED = “YES”,
DS_MIGRATE = “NO”
TM_MAD_CONF = [
NAME = “dev”, LN_TARGET = “NONE”, CLONE_TARGET = “NONE”, SHARED = “YES”
TM_MAD_CONF = [
NAME = “vcenter”, LN_TARGET = “NONE”, CLONE_TARGET = “SYSTEM”, SHARED = “YES”
Datastore Manager Driver Behavior Configuration
The configuration for each driver is defined in DS_MAD_CONF. These
DS_MAD section
required_attrs : comma separated list of required attributes in the DS
template
persistent_only: specifies whether the datastore can only manage persistent
images
DS_MAD_CONF = [
NAME = “ceph”,
REQUIRED_ATTRS = “DISK_TYPE,BRIDGE_LIST”,
PERSISTENT_ONLY = “NO”,
MARKETPLACE_ACTIONS = “export”
DS_MAD_CONF = [
NAME = “dev”, REQUIRED_ATTRS = “DISK_TYPE”, PERSISTENT_ONLY = “YES”
DS_MAD_CONF = [
NAME = “iscsi_libvirt”, REQUIRED_ATTRS = “DISK_TYPE,ISCSI_HOST”,
DS_MAD_CONF = [
NAME = “dummy”, REQUIRED_ATTRS = “”, PERSISTENT_ONLY = “NO”
DS_MAD_CONF = [
NAME = “fs”, REQUIRED_ATTRS = “”, PERSISTENT_ONLY = “NO”,
DS_MAD_CONF = [
NAME = “lvm”, REQUIRED_ATTRS = “DISK_TYPE,BRIDGE_LIST”,
DS_MAD_CONF = [
NAME = “vcenter”,
REQUIRED_ATTRS = “VCENTER_INSTANCE_ID, VCENTER_DS_REF, VCENTER_DC_REF”,
MarketPlace Driver Behavior Configuration
The configuration for each driver is defined in MARKET_MAD_CONF. These
values are used when creating a new marketplaces and should not be modified
since they define the marketplace behavior.
name : name of the market driver
required_attrs : comma separated list of required attributes in the Market
template
app_actions: List of actions allowed for a MarketPlaceApp
- monitor The apps of the marketplace will be monitored
- create, the app in the marketplace
- delete, the app from the marketplace
public: set to yes for external marketplaces. A public marketplace can be
removed even if it has registered apps.
MARKET_MAD_CONF = [
NAME = “one”,
SUNSTONE_NAME = “OpenNebula.org Marketplace”,
APP_ACTIONS = “monitor”,
PUBLIC = “yes”
MARKET_MAD_CONF = [
NAME = “http”,
SUNSTONE_NAME = “HTTP server”,
REQUIRED_ATTRS = “BASE_URL,PUBLIC_DIR”,
APP_ACTIONS = “create, delete, monitor”
MARKET_MAD_CONF = [
NAME = “s3”,
SUNSTONE_NAME = “Amazon S3”,
REQUIRED_ATTRS = “ACCESS_KEY_ID,SECRET_ACCESS_KEY,REGION,BUCKET”,
Please edit the post above, selecting the regions and using “Preformatted text” so it’s readable.
Are you able to connect to the mysql instance with
the command client mysql https://docs.opennebula.org/5.4/deployment/opennebula_installation/mysql_setup.html, as root, and as oneadmin?
Yes,I am able to login
Please change master.one.org to localhost and restart the service of opennebula and opennebula-sunstone.
And also stop iptable service.
Make sure your 2633 port is open.
I did a new install. Thank you for helping
