Not able to set virtual machine's password through xml-rpc api's
I am using xml-rpc api’s to create VM. Here I am using template to set the password. the problem is it is not setting the password. Please help me for this template.
Template as follows
sm-vm222112048x86_64<FIRMWARE_SECURE>YES</FIRMWARE_SECURE><IMAGE_ID>1</IMAGE_ID>61440FILE<TEMPLATE_ID>1</TEMPLATE_ID>0.0.0.0VNC211sushil<START_SCRIPT_BASE64>startup_script_in_base64_format</START_SCRIPT_BASE64>YESYES<ONEGATE_ENDPOINT>http://onegate-endpoint.com:5030</ONEGATE_ENDPOINT><PASSWORD_BASE64>base64_encoded_password</PASSWORD_BASE64>211vn-01private-vn-01
could you block-quote the data as currntly it is not readable. You could use the preview pane to see what others will see…
<TEMPLATE>
    <NAME>sm-vm</NAME>
    <CPU>2</CPU>
    <VCPU>2</VCPU>
    <SOCKETS>2</SOCKETS>
    <CORES>1</CORES>
    <THREADS>1</THREADS>
    <MEMORY>2048</MEMORY>
    <OS>
        <ARCH>x86_64</ARCH>
    </OS>
    <DISK>
        <SIZE>61440</SIZE>
        <TYPE>FILE</TYPE>
    </DISK>
    <GRAPHICS>
        <LISTEN>0.0.0.0</LISTEN>
        <TYPE>VNC</TYPE>
    </GRAPHICS>
    <CONTEXT>
        <CORES>1</CORES>
        <USERNAME>sushil</USERNAME>
        <START_SCRIPT_BASE64>start_script_base64</START_SCRIPT_BASE64>
        <TOKEN>YES</TOKEN>
        <NETWORK>YES</NETWORK>
        <ONEGATE_ENDPOINT>http://onegate-endpoint:5030</ONEGATE_ENDPOINT>
        <PASSWORD_BASE64>encoded_base64_password</PASSWORD_BASE64>
    </CONTEXT>
    <TOPOLOGY>
        <CORES>1</CORES>
    </TOPOLOGY>
    <NIC>
        <NETWORK>vn-01</NETWORK>
        <NAME>private-vn-01</NAME>
    </NIC>
</TEMPLATE>
