One-$ prefix when instantiating machines
Dear all,
we have the problem that the virtual machines that are instantiated in VMWare are prefixed with “one-$$” (where $$ is a number) this name is then different than the actual hostname which causes problems e.g. with our monitoring.
Is there are way to remove or configure the prefix ?
Regards
Soeren
Unfortunately, the one- prefix is not configurable. It is hardcoded in the core and some features rely on that prefix.
What you can do is change the hostname to one-<id>. If the VM is contextualized, add to the template:
CONTEXT = [
    SET_HOSTNAME = "one-$VMID" ]
Regards
In OpenNebula 5.0, the VM names in vCenter would be configurable so they can match the name you give them in OpenNebula (without the one- prefix)
hello, i installed OpenNebula 5.0 but the vm still named with one-vmname…
where to setup it into OpenNebula 5.0 ?
Thanks
Please see the second note on the following section:
http://docs.opennebula.org/5.0/deployment/node_installation/vcenter_node_installation.html#step-3-importing-vcenter-clusters
