VM_PREFIX Implementation
I am attempting to change the VM naming convention from the default one-- structure to a custom prefix using the VM_PREFIX as denoted in the user guide (see quote below) but have been unsuccessful getting it to work.
Within the VM template, I have added it manually at the bottom of the template file using the advanced editor in the following ways (each without success):
VM_PREFIX = $i
VM_PREFIX = ‘$i’
VM_PREFIX = ($i)
I have also attempted to change the setting using the key-value tags method, but the resulting template file (and results) appear to be identical.
I have noticed that after making each of the changes, it appears that the system automatically adds a set of double-quotes (“”) around the string, and I am wondering if this is what is causing the system to not recognize the variable. However, I have been unable to escape the quotes so far.
Please let me know if you need any additional information.
vOneCloud 3.2.0, OpenNebula 5.6.0
See description above
VM naming would match the name description (passed through to VM_Prefix)
Expected results:’
VM naming retains “One-” syntax
Im trying it right now and its working as expected.
i can see two problems:
  • you need to update the OpenNebula host (pointing to one vCenter cluster), not the template. that means that if you have for example:
(updating host templates)
vCenter “Cluster a” ->OpenNebula host_id 0: VM_PREFIX = “a-$i-”
vCenter “Cluster b” ->OpenNebula host_id 1: VM_PREFIX = “b-$i-”
when you deploy a machine from a OpenNebula template if the new vm go to cluster a it will have the name a-0-templatename.
  • use double quotes when using your editor with onehost update:
    VM_PREFIX=“custom_name-$i”
Regards
