bokus
(Bojan Zivancevic)
October 4, 2016, 3:10pm
1
Trying to enable oneflow to be shown in the GUI. OpenNebula 5.0.2. The service is running, I can see this from the CLI. Also I can see that the documentation is showing some screenshots where oneflow is a separate menu item on the left side of the screen. I do not have this.
Should I enable something in the config files?
Thanks
cmartin
(Carlos Martín)
October 4, 2016, 3:53pm
2
Is this a clean installation? By default you should see Instances/Services and Templates/Services.
If you don’t, it may be because you customized or used an old view.yaml file. See here for more information:
http://docs.opennebula.org/5.0/deployment/sunstone_setup/suns_views.html#defining-a-new-opennebula-sunstone-view-or-customizing-an-existing-one
bokus
(Bojan Zivancevic)
October 5, 2016, 8:18am
3
Yes this is a clean install, and yes I can see the templates->services menu. I am talking about this part in the user guide:
http://docs.opennebula.org/5.0/advanced_components/application_flow_and_auto-scaling/appflow_use_cli.html
As you can see OneFlow is shown in the main menu. Now, does it show up only after I have set up some services and roles and so on?
cmartin
(Carlos Martín)
October 5, 2016, 8:36am
4
That is an outdated screenshot. The menu was restructured, you must use Instances/Services and Templates/Services.
