OpenNebula UI not showing Infrastructure Tab
Installed OpenNebula 6.2.0 but looks like its showing very less options, Do I need to do any config changes ?
Basically I want to add vCenter , tried it using backend command onevcenter, but it’s giving message “No new clusters found in QA…”
Please support and provide some guidance how to get all tabs and menus on UI.
In the screenshot that you’re provided you can see OneProvision GUI.
It’s a powerfull tool to deploy Edge Clusters in some minutes and you can read more about it here.
But the interface that you’re looking for is called Sunstone. You can read here more about this GUI and how to import hosts from vCenter.
