OpenNebula 5.8 in Debian
Hi!
I am trying to test version 5.8.
Feels like I am missing something but I am getting a versioning error when attempting to install OpenNebula 5.8 on Debian 9.
root@one:/home/vagrant# apt-get install opennebula
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 opennebula : Depends: libmariadbclient18 (>= 10.1.37-0+deb9u1) but 10.1.26-0+deb9u1 is to be installed
E: Unable to correct problems, you have held broken packages.
Looks like OpenNebula is requesting a version of MariaDB that it is not available in Debian 9.
According to installation manual this version supports Debian 9, what am I missing?
Hey,
you are missing the security repository. libmariadbclient18 version 10.1.37 is in the security suite for Debian 9. See: https://packages.debian.org/search?keywords=libmariadbclient18&searchon=names&suite=stable&section=all
You should add something like:
deb http://security.debian.org/ stretch/updates main contrib non-free
deb-src http://security.debian.org/ stretch/updates main contrib non-free
to your /etc/apt/sources.list
thanks! will try it.
don’t know why is it missing! is not provided by default?
maybe my ansible script took it off by accident. will check.
@roedie you were right, that was the problem
