[Solved] No package opennebula in debian
Hello.
In docs Front-end Installation — OpenNebula 5.4.15 documentation on debian need install package opennebula, but apt didn`t found it.
root@prolan:/# apt search opennebula
Sorting… Done
Full Text Search… Done
libopennebula-java/stable 5.4.6-1 all
Java bindings for OpenNebula Cloud API (OCA)
libopennebula-java-doc/stable 5.4.6-1 all
Java bindings for OpenNebula Cloud API (OCA) - documentation
novnc/oldstable 1:0.4+dfsg+1+20131010+gitf68af8af3d-4 all
HTML5 VNC client - daemon and programs
opennebula-common/stable 5.4.6-1 all
empty package to create OpenNebula users and directories
opennebula-context/oldstable 4.8.1-1 all
contextualization package
opennebula-flow/stable 5.4.6-1 all
Manage services.
opennebula-gate/stable 5.4.6-1 all
send information to OpenNebula from the Virtual Machines.
opennebula-node/stable 5.4.6-1 all
empty package to prepare a machine as OpenNebula Node
opennebula-sunstone/stable 5.4.6-1 all
web interface to which executes the OpenNebula cluster services
opennebula-tools/stable 5.4.6-1 all
Command-line tools for OpenNebula Cloud
python-novnc/oldstable 1:0.4+dfsg+1+20131010+gitf68af8af3d-4 all
HTML5 VNC client - libraries
ruby-opennebula/stable 5.4.6-1 all
Ruby bindings for OpenNebula Cloud API (OCA)
How i can install Opennebula from package?
Hello, did you run apt-get update? I checked both (version 9 and 8) repos and I see opennebula package
Sorry, trouble in architecture. In x86_64 all ok.
