hi
about VMRC console
is it possible to switch “open in a new window” on and off somehow? in older version it was in the same window, and you could click the red X to exit the console
is it possible to disable the display being refreshed several times to adjust resolution?
thank you
hi
about the closing of the window, i’ve added a button myself by editing the vmrc.erb file
i’ve also noticed that this file contains the behavior of the auto-resize of the vm’s console. can you tell me where can i disable it in this file? vmrc.erb (7.0 KB)
