Hi there,
Does anyone integrated opennebula with nsx-t ipam feature ?
Is it possible to share configuration file to perform this task ?
Thank you.
Hi there,
Thank you.
Could you explain a bit what you want to do?
I Would like to delegate IP lease management to an external component. In this case I Would like my external component to be nsx-t.
Thank you
Thank you for your feedback.
I’ve openned an enhanced issue for this feature for future releases, but this feature was not in roadmap. So there is no estimation time to implement the feature.
You can follow the advances in:
If you’re really interested in this feature, please consider our Fund a Feature program: https://support.opennebula.pro/hc/en-us/articles/208670376-Development-Services-Guide
Thank you for your reply .
Regards
