HI,
I tried to install Opennebula in Ubuntu 14.04.
After installation i tried to start opennebula service.
when i use command
service opennebula start
I receive this error
Database version mismatch. Check oned.log.
oned failed to start
/usr/bin/one: line 117: 780 Terminated $ONE_SCHEDULER
Thanks in advance.
Pecadis
(Pecadis)
March 6, 2017, 1:29pm
#2
Hi Sathesh,
what is the log message of oned.log?
Pecadis
I solved the above problem but now struck in another problem.
When i try to login in sunstone, it displays invalid username pasword error
I have attached the one_auth for username and passwprd TERMINAL (27.6 KB)
When I try to login in sunstone using the same username and password, it displays error message. SUNSTONE (34.8 KB)
SUNSTONE LOG
Mon Mar 06 13:00:40 2017 [E]: User oneadmin could not be authenticated
Mon Mar 06 13:00:40 2017 [E]: Connection refused - connect(2)
Mon Mar 06 13:00:40 2017 [I]: Unauthorized login attempt
Mon Mar 06 13:00:40 2017 [I]: 127.0.0.1 - - [06/Mar/2017 13:00:40] “POST /login HTTP/1.1” 401 - 0.0042
Thanks in advance…
Sameer
(Sameer Varshney)
March 7, 2017, 6:04pm
#4
What errors are you getting in oned.log?
Are you using the default SQLite or MySQL?
If MySQL, check if its running. Also try with starting oned (oned start)
