Hi, I need configure a diferent tenants in opennebula.
I see the documentation and I see that it’s not possible. The solution is create a diferent user groups and assign the VMs that can manage? It’s correct?
Another question, it’s possible to configure a user group that only can start/stop/reset VMs and open a VNC console? For defect, user can delete a VM. I don’t want that the user can do this action.
correct?
Yes
Right now, you can just define the actions available at the interface level
in the /etc/one/sunstone-views/
