i have a probleme to create host in open nebula
Hello!
Do you have access to that hostname?
hostname=vcenter.vcenter3??
no i don’t have access in this name i would create a new host
https://docs.opennebula.org/5.4/deployment/node_installation/vcenter_node_installation.html
“Step 1: Check connectivity
The OpenNebula Front-end needs network connectivity to all the vCenters that it is supposed to manage.”
Try ip address instead of hostname
I do but that’s the same problem
