I encountered a problem during database migration from Opennebula 5.10 to 5.12. After onedb upgrade command I see an error
> Attemp to run migrators compiled in other versionCompiled: 2.0, installed: 2.6
The function which generates this:
def load_bytecode(file)
file = File.open(file, 'rb')
data = file.read
file.close
data = Zlib::Inflate.inflate(data)
data = Marshal.load(data)
c_ruby_version = Gem::Version.new(data.to_a[1..2].join('.'))
i_ruby_version = Gem::Version.new(RUBY_VERSION.split('.')[0..1].join('.'))
if c_ruby_version != i_ruby_version
raise 'Attemp to run migrators compiled in other version' \
"Compiled: #{c_ruby_version}, installed: #{i_ruby_version}"
end
new_iseq = RubyVM::InstructionSequence.load(data)
new_iseq.eval
end
I thought that’s because i had different versions of ruby as a root (2.0.0.) and as a user (2.6.3). After change this (to 2.6: root has 2.6.6. and user has 2.6.3. version of ruby) I see the same error.
I tried run onedb upgrade command as a root too, but I encountered different problem:
> /usr/lib/one/ruby/opennebula/xml_utils.rb:144:in module:OpenNebula’: nokogiri gem not installed. (RuntimeError)`
Installation attempt failed:
Building native extensions. This could take a while...
ERROR: Error installing nokogiri:
ERROR: Failed to build gem native extension.
current directory: /opt/rh/rh-ruby26/root/usr/local/share/gems/gems/nokogiri-1.10.10/ext/nokogiri
/opt/rh/rh-ruby26/root/usr/bin/ruby -I /opt/rh/rh-ruby26/root/usr/share/rubygems -r ./siteconf20201103-67319-1vhrfa9.rb extconf.rb
mkmf.rb can't find header files for ruby at /opt/rh/rh-ruby26/root/usr/share/include/ruby.h
You might have to install separate package for the ruby development
environment, ruby-dev or ruby-devel for example.
extconf failed, exit code 1
Gem files will remain installed in /opt/rh/rh-ruby26/root/usr/local/share/gems/gems/nokogiri-1.10.10 for inspection.
Results logged to /opt/rh/rh-ruby26/root/usr/local/lib64/gems/ruby/nokogiri-1.10.10/gem_make.out
I solved the problem with nokogiri - rh-ruby26-ruby-devel.x86_64 0:2.6.2-118.el7 package was missing. After that i tried to run onedb upgrade as root and I still have the same error: > Attemp to run migrators compiled in other versionCompiled: 2.0, installed: 2.6
I removed migration package, changed ruby version from 2.0.0. to 2.6.2, compiled migration package once again and I received the same error:
but i think installation did not end correctly:
opennebula-migration-community*.rpm
# Copyright 2019-2020, OpenNebula Systems S.L. #
# Licensed under the OpenNebula Software License for Non-Commercial Use #
# (the "License"); you may not use this file except in compliance with #
# the License. You may obtain a copy of the License as part of the software #
# distribution. #
# See https://github.com/OpenNebula/one/blob/master/LICENSE.onsla-nc #
# (or copy bundled with OpenNebula in /usr/share/doc/one/). #
# Unless agreed to in writing, software distributed under the License is #
# distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY #
# KIND, either express or implied. See the License for the specific language #
# governing permissions and limitations under the License. #
OpenNebula Community Edition Migration package is distributed under the above
license only for non-commercial use. By installing the package, you agree with
the license. Installation will automatically continue in 10 seconds ...
