[root@sunstone-slave ~]# onedb upgrade -v -S localhost -d opennebula
Version read:
Shared tables 5.6.0 : Database migrated from 5.4.1 to 5.6.0 (OpenNebula 5.6.0) by onedb command.
Local tables 5.6.0 : Database migrated from 5.4.1 to 5.6.0 (OpenNebula 5.6.0) by onedb command.
MySQL dump stored in /var/lib/one/mysql_localhost_opennebula_2019-3-12_11:44:46.sql
Use ‘onedb restore’ or restore the DB using the mysql command:
Running migrators for shared tables
Database already uses version 5.6.0
Running migrators for local tables
Running migrator /usr/lib/one/ruby/onedb/local/5.6.0_to_5.7.80.rb
undefined method error_message' for #<VCenterConf:0x000000030c1090> /usr/lib/one/ruby/vcenter_driver.rb:56:in rescue in initialize’
/usr/lib/one/ruby/vcenter_driver.rb:52:in initialize' /usr/lib/one/ruby/vcenter_driver.rb:91:in new’
/usr/lib/one/ruby/vcenter_driver.rb:91:in <module:VCenterDriver>' /usr/lib/one/ruby/vcenter_driver.rb:89:in <top (required)>’
/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55:in require' /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55:in require’
/usr/lib/one/ruby/onedb/local/5.6.0_to_5.7.80.rb:23:in <top (required)>' /usr/lib/one/ruby/onedb/onedb.rb:230:in load’
/usr/lib/one/ruby/onedb/onedb.rb:230:in apply_migrators' /usr/lib/one/ruby/onedb/onedb.rb:179:in upgrade’
/usr/bin/onedb:389:in block (2 levels) in <main>' /usr/lib/one/ruby/cli/command_parser.rb:470:in call’
/usr/lib/one/ruby/cli/command_parser.rb:470:in run' /usr/lib/one/ruby/cli/command_parser.rb:84:in initialize’
/usr/bin/onedb:294:in new' /usr/bin/onedb:294:in ’
The database will be restored
What is the problem ?
