Undefined method `chomp' for true:TrueClass while upgrading from 5.11 to 5.12
Following the announcement this morning of public release for 5.12, I decided to upgrade from 5.11 to 5.12
I followed exactly the upgrade process at Upgrading Single Front-end Deployments — OpenNebula 5.12.13 documentation
but at step 7, I encounter the following issue:
oneadmin@vlab:~> onedb upgrade -v
Unable to parse oned.conf: undefined method `chomp’ for true:TrueClass
if I try this, though, it works but says that my DB is upgraded to 5.10 and not 5.12. Not sure if this is correct?
oneadmin@vlab:~> onedb upgrade -v -S localhost -u oneadmin -p xxxxx -d opennebula
Version read:
Shared tables 5.10.0 : Database migrated from 5.6.0 to 5.10.0 (OpenNebula 5.9.80) by onedb command.
Local tables 5.10.0 : Database migrated from 5.8.0 to 5.10.0 (OpenNebula 5.9.80) by onedb command.
MySQL dump stored in /var/lib/one/mysql_localhost_opennebula_2020-6-18_22:21:28.sql
Use ‘onedb restore’ or restore the DB using the mysql command:
>>> Running migrators for shared tables
Database already uses version 5.10.0
>>> Running migrators for local tables
Total time: 0.41s
oneadmin@vlab:~>
Hello @saint
There was a bug in the documentation, the right command needs to specify the connection parameters. Run the command onedb upgrade with all the connections parameters, for example for MySQL:
onedb upgrade -v -S localhost -u oneadmin -p oneadmin -d opennebula
This has been fixed in the official documentation already.
