When I try to Import the Wilds, nothing happens…
When I press the Import Wilds button, nothing at all happens.
Thanks for help.
Thanks for help.
Could you share your /var/log/one/oned.log file on that time interval?
Mon Sep 23 07:26:00 2019 [Z0][ReM][D]: Req:3280 UID:0 IP:127.0.0.1 one.host.info invoked , 0
Mon Sep 23 07:26:00 2019 [Z0][ReM][D]: Req:3280 UID:0 one.host.info result SUCCESS, “0<NAM…”
Mon Sep 23 07:26:00 2019 [Z0][ReM][D]: Req:4544 UID:0 IP:127.0.0.1 one.system.config invoked
Mon Sep 23 07:26:00 2019 [Z0][ReM][D]: Req:4544 UID:0 one.system.config result SUCCESS, “<API_LIST_…”
Nobody has an idea?
The problem is remaining…
Hello @RimRex
Does the import work using CLI?
How can I do the Import over the CLI?
$ onehost importvm --help
## USAGE
importvm <hostid> <name>
Import VM to OpenNebula
## OPTIONS
-h, --help Show this message
-V, --version Show version and copyright information
--user name User name used to connect to OpenNebula
--password password Password to authenticate with OpenNebula
--endpoint endpoint URL of OpenNebula xmlrpc frontend
$ onevcenter import --help
## USAGE
import [<oid>]
Import the the desired vCenter object
Examples:
- importing first datastore
onevcenter list -o templates -h <host_id>
- importing 2 concrete templates:
onevcenter import "vm-1252, vm-553, vm-1248" -o templates -h <host_id>
- importing a image range:
onevcenter import 0..10 -o images -h <host_id> -d <ds-img_id>
valid options: object, host, datastore
## OPTIONS
-o, --object object vCenter object: [datastores, templates,networks,
datastores, images]
-h, --host host_id OpenNebula host used to authenticate the
operation
-d, --datastore datastore_id OpenNebula datastore used
I don’t have the onecenter bash…
When I try to import with onehost, it is shown that no host is named like DMIC_SIA-DMI_FS01.
Looks like you are missing the " - Cluster 1" suffix
Any Ideas?
When passing arguments with spaces to a process in the command line, you must use single (or double, if var substitution is needed) quotes.
Try upgrading to 5.8.5 if you are on an older version
Importing wild VMs not working on 5.8.5. It’s not working since 5.8.1. I was an opened issue on GitHub but nothing resolved and the issue closed.
Hi Anton,
Are you referring to this issue? https://github.com/OpenNebula/one/issues/3533
We need more feedback to reproduce and reopen the ticket.
Any Ideas?
