Hi all, I just written nodejs script which generates shorewall rules and dnsmasq dhcp reservations. It’s not node package yet, but I like to share and have your feedback. You can find it here
I also want to write some how to configure shorewall and dnsmasq for private network.
Hi Feldsam
thanks for your reply,
in fact my question was Howto integrate your JS script with Opennebula ? Or should i just call it outside of Opennebula ?
Best regards,
I see yes, you have to just call it on router node, best way is add to crontab and run every minute. It communicate with opennebula just over xml-rcp api.
It read all running VMs and search for PORTFORWARD variable in User template. Them generate rules. Also, it generate dhcp leases for dnsmasq
Also you have to execute shorewall service reload and dnsmasq service reload. Look at lines 25 and 34, that console.log should be replace by if(updated){ do something; } for example you can use shelljs node package, load it by require("shelljs/global"); and call exec('systemctl reload shorewall') or something like that.
lol … The level is still high for me
need to do current_Level-5 to get mine.
i have Opennebula running fine
I have deployed some VMs
I need to be able to define some portforwarding that will be activated after VM deployment
You script is giving a solution acceptable for me (many thanks)
I need now to know:
5.1 Should i git clone your script anywhere ?
5.2 After i git clone it, how to call/run it ? Is it by calling it in html ? in bash ? or …?
5.3 Remember I never did something with nodeJS
install nodejs and npm to you linux machine
download an unpack zip
cd into unpacked source code and run npm install - it install dependencies
open index.js and edit line 8 - set your oneadmin password and url of frontend
run node index.js
two files should be created shorewallRules and dhcpConf
If all is without errors, you can try to add PORTFORWARD variable to VM.USER_TEMPLATE - so open some running VM instance and add new variable at the bottom of VM page. For example you can just forward port 80/tcp, so as variable value u set 80/tcp
run again node index.js
look at generated file cat shorewallRules and you should see generated DNAT rule
After test, you can adjust config variables in index.js file, like IP addresses, reserved ports, file paths… and include rules file in shorewall rules file by SHELL cmd…
Don’t worry, i’m used to start from Zero on things more complex
I’ve just seen your mail, i did that and i receved this error:
TypeError: Cannot call method ‘split’ of undefined
at Object.toInt [as toLong] (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/ip/lib/ip.js:364:6)
at /var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/index.js:342:26
at /var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/lib/vnet.js:9:5
at /var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/lib/modem.js:31:9
at Parser. (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/node_modules/xml2js/lib/xml2js.js:384:20)
at Parser.EventEmitter.emit (events.js:95:17)
at Object.onclosetag (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/node_modules/xml2js/lib/xml2js.js:348:26)
at emit (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/node_modules/xml2js/node_modules/sax/lib/sax.js:615:33)
at emitNode (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/node_modules/xml2js/node_modules/sax/lib/sax.js:620:3)
at closeTag (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/node_modules/xml2js/node_modules/sax/lib/sax.js:861:5)
at Object.write (/var/lib/one/utils/one-shorewall-dnsmasq-rules-generator/node_modules/opennebula/node_modules/xml2js/node_modules/sax/lib/sax.js:1294:29)
