[SOLVED] Dedicated marketplace for LXD
Hello.
The blog entry regarding lxd talks about a " dedicated marketplace for LXD". Where do i find this and how do i add this to my instance?
thanks and cheers
t.
Hello @himbeere
It’s added by default, you can find more information here http://docs.opennebula.org/5.8/advanced_components/marketplace/market_lxd.html
Thanks for you answer. I guess i’m missing something in oned.conf.
oneadmin@one:~$ onemarket create lxcmarket.cfg
[one.market.allocate] MARKET_MAD_CONF named "linuxcontainers" is not defined in oned.conf
oneadmin@one:~$
Do you have a snippet for me which solves that issue?
thanks and cheers
You need to place this in your oned.conf (/etc/one/oned.conf)
MARKET_MAD_CONF = [
   NAME = "linuxcontainers",
   SUNSTONE_NAME = "LinuxContainers.org",
   REQUIRED_ATTRS = "",
   APP_ACTIONS = "monitor",
   PUBLIC = "yes"
After that, restart OpenNebula using one restart or via systemctl.
Thanks that worked allthough it seems to be empty right now. I’ll wait a bit.
Yes, you have to wait the number of seconds set in MONITORING_INTERVAL_MARKET.
Yeah. Works. Thanks Alejandro. Let’s got test deeper. :slight_smile:
Yeah! No problem!
Maybe while we just talk. Can you give me a quick answer to Lxd + kvm host at the same time?
thanks and cheers
